barry1me Posted April 24, 2016 Report Share Posted April 24, 2016 Anyone else that is running a 15t and a TM design works case saver notice chain rub? Im sure its not a big deal as this will wear in but I was a bit suprised by this. I was wondering if it had to do that I was running a 520MX chain (maybe a tad bigger then standard 520) Quote Link to comment Share on other sites More sharing options...
Craig B Posted April 24, 2016 Report Share Posted April 24, 2016 Anyone else that is running a 15t and a TM design works case saver notice chain rub? Im sure its not a big deal as this will wear in but I was a bit suprised by this. I was wondering if it had to do that I was running a 520MX chain (maybe a tad bigger then standard 520) I had the same problem. I just ran that bitch and it self clearanced 16 tooth would need some work. 1 Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted April 24, 2016 Report Share Posted April 24, 2016 I use a porting tool to clearance , I've never ran one 1 Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted April 24, 2016 Report Share Posted April 24, 2016 Which one, this one? I'd say a days worth of riding will wear down any excessive poly urethane.. Or be proactive like Sleeper said and just grind a little away and be done! https://www.ebay.com/ulk/itm/401070684179 Quote Link to comment Share on other sites More sharing options...
LaegerEliminator Posted April 24, 2016 Report Share Posted April 24, 2016 I used an air dremel style grinder with barrel cutter and clearanced mine to accept up to a 16t Quote Link to comment Share on other sites More sharing options...
barry1me Posted April 24, 2016 Author Report Share Posted April 24, 2016 Which one, this one? I'd say a days worth of riding will wear down any excessive poly urethane.. Or be proactive like Sleeper said and just grind a little away and be done! https://www.ebay.com/ulk/itm/401070684179 yes this one. Maybe some dyno time tomorrow will work it in. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 25, 2016 Report Share Posted April 25, 2016 yes this one. Maybe some dyno time tomorrow will work it in.pushing the bike back and forth will work. Quote Link to comment Share on other sites More sharing options...
