Banshee not starting
Will910
Had a previous problem, carbs pouring gas, now fixed by tightening drain bolt, now carbs hold gas. However now other problems occur.
Checked the spark plugs, dry no gas going to cylinders, pulled carbs, intake side dry no gas inside, could this be a problem with the reeds not functioning correctly and failing to suck gas into the motor?
That's the choke crossover tube. But the choke is actually a fuel enricher, when you pull the knob out on the left carb, it sucks up fuel and passes it to the other carb via that hose. When left off you have two large air leaks. Enough your quad will not kick start. You could probably drag it and bump start it but it will run bad and melt down from a lean condition.
