Will910 Posted April 23, 2016 Report Share Posted April 23, 2016 Had a previous problem, carbs pouring gas, now fixed by tightening drain bolt, now carbs hold gas. However now other problems occur. Checked the spark plugs, dry no gas going to cylinders, pulled carbs, intake side dry no gas inside, could this be a problem with the reeds not functioning correctly and failing to suck gas into the motor? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 23, 2016 Report Share Posted April 23, 2016 Is this black hose installed between the 2 carbs? Quote Link to comment Share on other sites More sharing options...
Will910 Posted April 23, 2016 Author Report Share Posted April 23, 2016 No, only the 2 fuel lines that come from each and come together into one, is that the same thing? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 23, 2016 Report Share Posted April 23, 2016 No, look at pic. Hose is opposite choke on left carb. Fuel hose is more towards the back. Quote Link to comment Share on other sites More sharing options...
Will910 Posted April 23, 2016 Author Report Share Posted April 23, 2016 Oh, in that case my carbs dont have that hose, what is it, and is it necessary for the bike to run, have seen brand new carbs that dont have it. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted April 23, 2016 Report Share Posted April 23, 2016 Stock carbs won't run for shit without it. sent from yo mammy house. 1 Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 23, 2016 Report Share Posted April 23, 2016 (edited) Carbs clean? You can see light through main and pilot jet? Blow air through all passages? Correct bowl on left carb ? Notice e red arrow pointing to the "BB" on left carb bowl? Edited April 23, 2016 by Larry's Shee Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 23, 2016 Report Share Posted April 23, 2016 Do you have stock carbs like those pictures? Quote Link to comment Share on other sites More sharing options...
Will910 Posted April 23, 2016 Author Report Share Posted April 23, 2016 Yea I have stock carbs, similar to the picture, including the tors delete. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 23, 2016 Report Share Posted April 23, 2016 Well, it will NOT start without that hose installed. 1 Quote Link to comment Share on other sites More sharing options...
Will910 Posted April 23, 2016 Author Report Share Posted April 23, 2016 Ok, thanks for the info, just curious what is this hose, and what does it do that will prevent the bike running, witout it installed. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 23, 2016 Report Share Posted April 23, 2016 That's the choke crossover tube. But the choke is actually a fuel enricher, when you pull the knob out on the left carb, it sucks up fuel and passes it to the other carb via that hose. When left off you have two large air leaks. Enough your quad will not kick start. You could probably drag it and bump start it but it will run bad and melt down from a lean condition. Quote Link to comment Share on other sites More sharing options...
Will910 Posted April 24, 2016 Author Report Share Posted April 24, 2016 Oh man thank you for letting me know, dodged a bullet there, thanks in advance, ordered the part should hopefully be up and running soon, I appreicate all the help. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 24, 2016 Report Share Posted April 24, 2016 Oh man thank you for letting me know, dodged a bullet there, thanks in advance, ordered the part should hopefully be up and running soon, I appreicate all the help.You ordered a cross over tube??Any hose that size would've worked Quote Link to comment Share on other sites More sharing options...
oldskool Posted April 24, 2016 Report Share Posted April 24, 2016 I think i have cut a piece off from gas cap vent hose before. Quote Link to comment Share on other sites More sharing options...
