barry1me Posted April 21, 2016 Report Share Posted April 21, 2016 Hey guys Im going to install my Alba LT suspension tomorrow night. Im looking for some feedback on best ( or maybe easiest) way to do an alignment to set Toe and camber. I have read some people put a chalk mark line in middle of tire on both fronts and measure in front of bumper, then roll quad back and measure the mark 180 degree back from there. Is this the best method? Also I need to figure out how to do Camber. What degree camber and toe would you guys recommend? Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted April 21, 2016 Report Share Posted April 21, 2016 I measure the height of the front tire, divide it in half, mark the point @ the 3 & 9 position with a piece of tape so I can replicate precise measurements.Then I follow this LSR guide for recommended settings.... http://lsracing.com/img/Guide_21.pdfUsing one of theses from Harbor Freight... http://www.harborfreight.com/dial-gauge-angle-finder-34214.html That's all you need to know! 1 Quote Link to comment Share on other sites More sharing options...
vrx46 Posted April 21, 2016 Report Share Posted April 21, 2016 Wood and a tape measure Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted April 22, 2016 Report Share Posted April 22, 2016 I do car alignments at work. I wish I could make it work for the bike. I think it's wide enough to fit on the wrack. I think it's 46" between the two platforms for the lift. My boss told me he will help me and do it with chalk on the ground though Quote Link to comment Share on other sites More sharing options...
registered user Posted April 22, 2016 Report Share Posted April 22, 2016 toe I used a tape measure. rest of the shit I just eyeballed 1 Quote Link to comment Share on other sites More sharing options...
barry1me Posted April 22, 2016 Author Report Share Posted April 22, 2016 I measure the height of the front tire, divide it in half, mark the point @ the 3 & 9 position with a piece of tape so I can replicate precise measurements. Then I follow this LSR guide for recommended settings.... http://lsracing.com/img/Guide_21.pdf Using one of theses from Harbor Freight... http://www.harborfreight.com/dial-gauge-angle-finder-34214.html That's all you need to know! How much negative camber do you run? I was thinking 1.5-2 degree. Is 1/4 inch toe in kind of the standard? Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted April 26, 2016 Report Share Posted April 26, 2016 How much negative camber do you run? I was thinking 1.5-2 degree. Is 1/4 inch toe in kind of the standard? I run 4º caster, 3º camber, I shoot for between 1/8-1/4" toe-in. Seems to be stable at speed and turns ultra well. Gotta have good front tires tho. I've tried Mohawks and SandStars... I like STU's hands down. Waaayyy lighter too! Quote Link to comment Share on other sites More sharing options...
