Whos selling the power valve cub cylinders
junkyarddog
Yes. Cheetah..... Just Cheetah, is pretty much a cub cyl with power valves and 250r intakes.
Cheetah
Cheetah cub
Serval cub
Wampus cub
Wampus serval (wampus cyls are meant to look stock)
Super (means 72mm bore in any of the above combos)
DM (74mm-80mm ish)
DMX (80+ mm)
Then you get the real monsters Jmadd mentioned which are all spread bore and even larger bores then the DMX. Spread bore means the cylinders are located further apart then stock. That allows them to make the transfers larger to feed the larger motors.
Gotcha. If I'm worng, please correct me. Not all the cheetahs are gonna be a pv, right?
Serval cub is just referred as serval for short. Cheetah cub is called cub for short also. Am I seeing this clearly?
And you don't see many cheetahs because trinity own it
and then look at the big time big $$ shops  those spread bore using banshee based cases and billet transmissions are pretty one off specialized builds that are prone to destruct..  big power but in my opinion overall a bad design as far as any kind of reliability.
no matter what still pretty saweet really
  • 1 month later...
