junkyarddog Posted April 19, 2016 Author Report Share Posted April 19, 2016 Thanks for the links trickedcarbine Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
junkyarddog Posted April 19, 2016 Author Report Share Posted April 19, 2016 On a stock stroke pump gas dunner 28mm carbs T-5 pipes what would your guys run? The driveline 68mm or cub 68mm Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
junkyarddog Posted April 19, 2016 Author Report Share Posted April 19, 2016 I seen a guy 2 weeks ago at the dunes running a stock stroke power valve cub and it ran amazing Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 20, 2016 Report Share Posted April 20, 2016 On a stock stroke pump gas dunner 28mm carbs T-5 pipes what would your guys run? The driveline 68mm or cub 68mm Sent from my iPad using Tapatalk Soooo..What happened to the stock cylinders? Quote Link to comment Share on other sites More sharing options...
junkyarddog Posted April 20, 2016 Author Report Share Posted April 20, 2016 That's the wife's bike and I was thinking doing mine but might as well spend a few more paychecks and do mine with a cub or maybe the driveline what ever seems to be better I don't know what's better and never had a cub so doing a lot of reading Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted April 20, 2016 Report Share Posted April 20, 2016 What type of riding do you do? You're all over the place here. If you're on a budget port your stock cylinders. Either way you will be in more then $400. Considering the other work you would need. sent from yo mammy house. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted April 20, 2016 Report Share Posted April 20, 2016 T5's on a cub. That shows you don't even wanna research the littlest bit. I'm done here. 2 Quote Link to comment Share on other sites More sharing options...
junkyarddog Posted April 20, 2016 Author Report Share Posted April 20, 2016 I see t-5 on Cubs all the time Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 20, 2016 Report Share Posted April 20, 2016 I see t-5 on Cubs all the time Sent from my iPad using Tapatalk I see spoilers on Honda civics all the time. 5 Quote Link to comment Share on other sites More sharing options...
junkyarddog Posted April 20, 2016 Author Report Share Posted April 20, 2016 Dune , play , maybe some fast sand trail Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
junkyarddog Posted April 20, 2016 Author Report Share Posted April 20, 2016 Ya in your garage Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 20, 2016 Report Share Posted April 20, 2016 Ya in your garage Sent from my iPad using Tapatalk Woah. Good one. 2 Quote Link to comment Share on other sites More sharing options...
salmon_slayer06 Posted April 20, 2016 Report Share Posted April 20, 2016 You won't see too many dune port jobs for less than 400. You'll be spending 800 or more for the whole job including honeing, pistons and chamfering Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted April 20, 2016 Report Share Posted April 20, 2016 Ya see 30's on a caprice too but that don't make it right 1 Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted April 20, 2016 Report Share Posted April 20, 2016 Someone's dune port could be another guys mx or trail. Ffs you gotta tell the builder what you do and want out of it Quote Link to comment Share on other sites More sharing options...
