I could use some help reading this plug.to me it looks like my pilot jet is good but the main might be a little lean. Wondering what that white stuff is on the tip of the plug
722a5c0c4bf673b8261e972f141d7364.jpg298d5dd41e93a6cb4dc47207e6efa1b3.jpgb1d018083e27adc8346b82a30558aff5.jpg
Sent from my SM-N920V using Tapatalk
Everyone says to ride to a long straight away put new plugs then ride through all the gears then turn it off and take the plugs out and then you chop em. Idk much about the process honestly, that's why I came here.
What plug you using?
Not sure on your procedure. Warm bike up on old plugs. Install new plugs. Ride WFO banging the gears, no pussy riding. When it stops pulling hard in 6th, pull in clutch and kill engine.
Read or chop plugs.
Thanks trickedcarbine, threw a 290 in there. I'll plug chop it again tmrw probably.
I'm using ngk b8es. That's pretty much the same procedure I do, but you worded it better
