maggdog Posted April 19, 2016 Report Share Posted April 19, 2016 The fucking right carb don't work, I plug the choke and work a little bit (good smoke) after a seconds again only air for that side (no smoke) I test changing position carb, left to right and viceversa, and the right cylinder works great with the left carb and the left cyl don't work with right carb I put all normally again try to cleaning but still bad, sometimes works with choke on or sometimes in high's rpms the carbs have TORS yet, but disconnected what can be the problem? problems discarded: ignition coil, spark plugs, carb sync Quote Link to comment Share on other sites More sharing options...
Motooutcastxxx Posted April 19, 2016 Report Share Posted April 19, 2016 Did you happen to mix up any of the parts between the 2 carbs? A couple of things are specific to the left/right carbs, if you mix them up they'll bolt up but you'll be chasing bugs kinda like you are now. Make sure your slides are in the right way, half moon cut-out goes towards the air box side and make sure the choke tube is on... Quote Link to comment Share on other sites More sharing options...
maggdog Posted April 19, 2016 Author Report Share Posted April 19, 2016 Did you happen to mix up any of the parts between the 2 carbs? A couple of things are specific to the left/right carbs, if you mix them up they'll bolt up but you'll be chasing bugs kinda like you are now. Make sure your slides are in the right way, half moon cut-out goes towards the air box side and make sure the choke tube is on... https://vimeo.com/163426018 Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 19, 2016 Report Share Posted April 19, 2016 plugged pilot jet 1 Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 19, 2016 Report Share Posted April 19, 2016 A quick douche with a spray can is NOT cleaning them. Must completely disassemble and soak or ultrasound. Must be able to blow air through all passages and see light through jets and sides of main jet/emulsion tube. Quote Link to comment Share on other sites More sharing options...
maggdog Posted April 19, 2016 Author Report Share Posted April 19, 2016 A quick douche with a spray can is NOT cleaning them. Must completely disassemble and soak or ultrasound. Must be able to blow air through all passages and see light through jets and sides of main jet/emulsion tube. I'll try that Quote Link to comment Share on other sites More sharing options...
maggdog Posted April 19, 2016 Author Report Share Posted April 19, 2016 plugged pilot jet Yes was its A quick douche with a spray can is NOT cleaning them. Must completely disassemble and soak or ultrasound. Must be able to blow air through all passages and see light through jets and sides of main jet/emulsion tube. I clean again all the carb and great!! fix it, fix my air compressor to fix the carb and nice, feel complete again Haha, thanks buddys Quote Link to comment Share on other sites More sharing options...
