Just curious if anyone was able to use the stock banshee springs on the underside of toomey T5 pipes or if you had to order shorter ones?? My stock ones are to long and not sure why. Toomey says they should fit. Any help would be great!
I have stock springs on our T5's had to pull like hell to get them on. Wrong springs?
Edited by Shifty722
I just looked at ours, your spring loop on the pipe is welded on in the wrong place, ours are almost on the bottom of the pipe, horizontal to the frame tube.
If these are new T5's send them back, or search for shorter springs.
I will try to post a pic.
Sent from my SM-G920V using Tapatalk
Edited by Shifty722
Hope this ^^^^ helps
