02Banshee88 Posted April 11, 2016 Report Share Posted April 11, 2016 I think I have an exhaust leak. First off, I was riding it about two weeks ago and the powerband wasn't happening at all. No bogging, just acceleration with no powerband. I fired up my Banshee today and saw a lot of smoke coming out of what I think was my exhaust clamp behind the carburetor that connect the two portions of the pipe. Could this be causing my powerband issue? Ima check for air leaks when I get a chance and do plug chops but I definitely feel like I have an exhaust leak. Close to the bottom of the engine near the front I heard a ticking noise. Not clinking or anything like the kick start rattle or natural ping of the engine itself, but a ticking sort of while it was idling, and something smelled like it was burning. Not the usual exhaust smell. I think I got a lot more problems than one. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 11, 2016 Report Share Posted April 11, 2016 It takes more then a leaky exhaust to make these things run the way you're describing. Do a compression test to verify there is life left in the motor, then start troubleshooting. Quote Link to comment Share on other sites More sharing options...
02Banshee88 Posted April 12, 2016 Author Report Share Posted April 12, 2016 It takes more then a leaky exhaust to make these things run the way you're describing. Do a compression test to verify there is life left in the motor, then start troubleshooting. Okay Quote Link to comment Share on other sites More sharing options...
