Yes you can. I just did that yesterday. Just seams easier to do it on a workbench.
Thanks that is what Im looking for...also does your bowl rub on clutch ?  BTW what size pods do you run?
Edited by barry1me
Different manifolds can get the bowl up off the clutch arm. You can loosen the clamp on the intake side of the carb and rotate it in a bit to access the bottom of the carb. Some kits designed for the banshee may have the access nut removed and the hole is just a welded plug so the whole bowl needs to come off. If there is a nut on the bottom, you can use that as a way to change the main, but not the pilot. The Bowl will need to be removed to do the pilot. It's just less trouble to pull the carb off to do all that.
Which manifold do you recommend?  I was planning to do the UPPs.  I have read people have issues with the UPP and billets with allowing the carbs to hit the clutch.
