ATVridinMaNiAc Posted April 9, 2016 Report Share Posted April 9, 2016 Hello I need the primary drive gear that bolts to basket along with the clutch cushion cover and 4 screws. Need also the primary driven gear that is on the crank shaft (larger of the 2). Then finally I need a waterpump impeller gear and dowel pin for it. Would preferably like to buy from someone who has all of it. Thanks. Quote Link to comment Share on other sites More sharing options...
m671054 Posted April 9, 2016 Report Share Posted April 9, 2016 Make sure the primary set matches. Verify numbers etched on gears are within specs in the book. Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted April 11, 2016 Author Report Share Posted April 11, 2016 No longer need waterpump gear or pin, everything else still needed. Quote Link to comment Share on other sites More sharing options...
m671054 Posted April 11, 2016 Report Share Posted April 11, 2016 Pretty shure mattoon sells a hd backing plate with cushions on ebay. Check there. Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted April 12, 2016 Author Report Share Posted April 12, 2016 Yea I will likely end up buying a new kit from redline with the bigger screws. I was just throwing it out there in case somehow had one along with the primary gears. Quote Link to comment Share on other sites More sharing options...
