421 Serval Part out. Lakers, Elka LT, Roll, Fireball, Hipers, ProPegs.
Pingle?
I have two. 90 per.
Your chain rollers good?
Yes, they're the raised center "power lip" TM rollers. 20
Woulda bought the motor along with the pipes if you put everything for sale at the same time
Sorry man, at the time I was still entertaining the idea of keeping the banshee and trying SLP's. First post was just random stuff that was laying on my parts bench.
Payment sent, updated shipping address in Pm. Forgot to change on the invoice.
Packaged and I have your work address on the package.
Pro pegs available still? Willing to ship north of the border?
They are. I can do that but the added shipping will be at your expense.
I will be heading out of town for the weekend so any parts that haven't been paid for today will ship Monday/Tuesday of next week. I'll keep up with messages and all through TapaTalk.
  • Like 1
Parting out my Red Laker 421 Serval. Doesn't get ridden enough to justify the money invested. All wear items (bearings, bushings, seals, chain etc..) were replaced during the build and have less than 5 hr's of ride time.
Prices include shipping to the lower 48, unless stated otherwise.
PayPal fees will have to be covered by the buyer or gifted payment sent.
PayPal is: BlakeRms288@yahoo.com
https://www.youtube.com/watch?v=yxAoMBPN7Fg
Pics and vid with 18" tire set up and 421 Engine. **Snipers are sold.**
Pics of the hipers and holeshots as well as the 28mm carbs and PT Mids on stock engine set up.
The parts from the 421 bike.
421 motor, harness - 2900 Sold
Ported serval by CamATV here on the forums, blasted and cleaned port matched cases, all new gaskets, bearings, seals, Custom domes by Cam, Trued and welded 4 mil long rod hot rods crank, Max load and TZ bearings, New Weisco pistons, rings, wrist pin bearing, Cam's promod trans, 15T sprocket, modded shift drum bearing, Billet shifter, Mull Eng. shift star, detend arm, and bearing,, Barnett billet 8 plate basket with spring cushions, F.A.S.T fibers and steels, billet pressure plate, HD springs, pancake bearing, straight cut stock ratio gears, Direct Drive Clutch cover, billet dip stick, Chariot Ultra high flow impeller and cover, Billet water pump gear, Chariot Stator cover with bearing support, Billet Mattoon neutral switch cover, Billet kicker (rock solid, no rattle or swinging out), Chariot cool head, V-Force 4 reeds, Billet intake with crossover. Have boots for anything from a 28mm carb to a 40mm, new clutch arm, spring, bearing and seal, as well as push rod and ball, 200wat DC Electrosport stator, brand new complete harness, coil, CDI. Basically every component was replaced new. Very clean, strong engine, not even completely broken in yet. Runs on Pump, 155PSI on each cylinder.
Magura Hydraulic clutch - 150 (100 if bought with the engine, I'd recommend it, the HD springs are no joke) Sold
28mm PWK's w/ cable - 250. Sold
Elka 19.5” quad rate fronts remote ressy's long braided hoses for option to mount under seat set up for Fb arms, 195# rider - 575 Sold
Fireball LT a arms - 475
Elka Dual rate rear - 550 Pending Payment
Roll Design -1 swing arm w/ carrier, RK 520 chain included - 600
Chrome LSR Anti-Vibe Steering stem w/ billet 1 1/8 clamp - 150 Sold
Flexx Bars - 160 - Sold
LED Light Cannons w/ lens covers - 350 Sold
AC ProPegs a little tweaked but in good useable shape, good nets, pegs sharp - 150
AC bumper no dents or bends - 75
YFZ Front spindles/hubs/calipers mint, new pads, Galfer wave rotors, braided stainless lines, MC with ASV C6 lever - 200 Pending Payment
Red Lakers F&R like new – 500 pickup or meet, shipping additional.
PT Mids High temp black, fresh packing, some dents – 300
Durablue X-33 axle, billet hubs, lock nut, billet sprocket hub Honda bolt pattern, 38T sprocket, billet disk hub w/ Galfer wave rotor – 320
Hiper single beadlocks w/ Holeshot XC’s 22/7/10 & 21/11/9, black rings, tires atleast 95% – 750
Sedona Bazooka tires and rolled lip black rims 19/6/10 front and 18/10/8 rear 95% tread - 350
Probably some things I'm missing, as parts get narrowed down I can refine the list.
If you have any questions about a specific part or would like more detailed pictures of something specific let me know. As it sits the banshee is still assembled.
Best price for the pt mids
Sent from my VS810PP using Tapatalk
