Banshee barn find help with 2 known issues
Mains were 200 or 210, I pulled one just to check, it's a slight issue, I believe it's not lean enough on the air screws so I'm gonna back out an 8th and go from there, very slight issue, if they were 240 it would fall flat all over without pipes, it's just a tiny throttle response issue about a quarter to mid, I may adjust needle clip positions if air screw adjustment doesn't clean it up.
Just sent you a message, I'm gonna dump the snorkel, which I intended on doing, see where it is, if it's still not right, I'll remove the lid, should be ok with the pro design filter and adaptor, if it's still not enough, I'll throw the lid on and out on the air screws an 8th and go from there, seems rich off throttle to just below half or a little less so I'll lean it a tad if increasing the air flow doesn't make the difference, should be fairly simple.
