Rage_kage Posted April 3, 2016 Report Share Posted April 3, 2016 I just came to the realization that my throttle is to hard to pull(stock housing, extended lever). I'm trying to work up some ideas. Is there a proven throttle assembly that has a easier pull? And if I where to cut my springs in the carb, how much do you normally take off? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 3, 2016 Report Share Posted April 3, 2016 Cuervo, Chariot. Quote Link to comment Share on other sites More sharing options...
camp0429 Posted April 3, 2016 Report Share Posted April 3, 2016 Honda 1 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 3, 2016 Report Share Posted April 3, 2016 HondaHonda throttle and fast ez pull springs. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted April 3, 2016 Report Share Posted April 3, 2016 Honda throttle and fast ez pull springs.Which Honda throttle to be exact? Trx450r? 400ex? Trx250r? Was thinking about getting one for my stock bike Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted April 3, 2016 Report Share Posted April 3, 2016 Honda throttle is cheap and works well. You can try cutting 1/4 coil from your slide springs. Chariot is nice (you saw mine) Cuervo is going to be decent $$$, I think my chariot was 150 but they can be had for cheaper. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted April 3, 2016 Report Share Posted April 3, 2016 Which Honda throttle to be exact? Trx450r? 400ex? Trx250r? Was thinking about getting one for my stock bikeI think they are all very similar and they should all work the same. I've used a 400ex throttle in the past (at least I think it was a 400 throttle) Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 3, 2016 Report Share Posted April 3, 2016 Which Honda throttle to be exact? Trx450r? 400ex? Trx250r? Was thinking about getting one for my stock bikeI think mine is a 400 ex. They all are the same I believe. But I heard trx90 was easier. I don't know if that's true though. Sent from my SAMSUNG-SM-G890A using Tapatalk Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted April 3, 2016 Report Share Posted April 3, 2016 I think they are all very similar and they should all work the same. I've used a 400ex throttle in the past (at least I think it was a 400 throttle)Thanks for clearing that up. To the op I believe FAST sells pre cut springs now check out their website Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted April 3, 2016 Report Share Posted April 3, 2016 Dats ghey ^^^ Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted April 3, 2016 Report Share Posted April 3, 2016 So is running a 66x58 cubIt just sits in the garage anyways Quote Link to comment Share on other sites More sharing options...
camp0429 Posted April 3, 2016 Report Share Posted April 3, 2016 My throttle came off a 250ex. Works great. I think the trx90 lever itself is longer 1 Quote Link to comment Share on other sites More sharing options...
Craig B Posted April 4, 2016 Report Share Posted April 4, 2016 I am using a Chariot thumb throttle and Fast ez pull springs for pwk's. Not sure if those spring would work on the stock 26mm. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 4, 2016 Report Share Posted April 4, 2016 How old is the cable? Quote Link to comment Share on other sites More sharing options...
Rage_kage Posted April 4, 2016 Author Report Share Posted April 4, 2016 (edited) 2 rides old, lubed after every ride Sent from my XT1585 using Tapatalk Edited April 4, 2016 by Rage_kage Quote Link to comment Share on other sites More sharing options...
