05banshee27 Posted April 2, 2016 Report Share Posted April 2, 2016 I'm trying to adjust my needle clip in my 34mm pwk keihin carb, but i can't figure out how to take it apart.... the spring inside is really tight Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 2, 2016 Report Share Posted April 2, 2016 Grip the cap with one hand and the slide with the other, now with the hand on the cap, wrap you're fingers around the spring and begin to compress it tight to the cap. Once it's compressed and not wiggling to much, push the cap and slide together and work the cable over in the notch And pull the slide off. The 1/4" hex is spring loaded and will need to be compressed and turned a quater turn counter clockwise. It will now release and allow you access to the needle. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted April 2, 2016 Report Share Posted April 2, 2016 Oh shit, just realized you said PWK not PJ's. Mostly the same except the 1/4 turn fitting inside the slide. That will need to be unscrewed. Quote Link to comment Share on other sites More sharing options...
05banshee27 Posted April 11, 2016 Author Report Share Posted April 11, 2016 Thanks I got it Quote Link to comment Share on other sites More sharing options...
