My leak down test results
tdod101
He never mentioned a builder. He didn't want to contact the builder.
He accepted the seal leak and was seeing where to go with it. He knew the motor was year out of the builders hands and knew nothing was going to be done one that end.
People kept prying at the name of the builder.
FFS parts can and will fail at times... If it's is someone's decision to use a used part there is def a higher possibility of the part failing. You choose a builder to intrust your motor with them. If something goes wrong then you simply contact your builder and get the issue fixed. They are more then likely to work and help fix the problem as earlier stated. The problem I see is that you didn't contact the builder after a problem was noticed. I understand everyone gets frustrated when things don't work out but what matters is how it's handled on both ends after something happens. I think you may releaize that now
He didnt bash the builder nor did he mention him? he just asked what to do now that he found a leaking seal....
Others pried for the builder name which was never mentioned.
He was pretty reserved on the whole matter.... non the less this isn't the 1st thread nor will it be the last with identical outcomes... shit will happen and people tend to get mad when things don't work out after spending coin and being patient...
Did you miss the part where he never called the builder?
Or the part where they BOTH did leak downs in August with no leaks?
Or that it was a USED crank?
Or the smartass comment "Ordered a new crank from FAST, thanks Jeff!"
The entire post made it sound like the builder sent it out like that.
He purposefully left out important info because people would jump his ass.
Pretty fucking absurd if you ask me.
Cliff notes.
  • Like 1
