Just bought 99 banshee
Take the cap that is on the end of your spark plug wire off your left spark plug. Put it on your right spark plug and the one from your right spark plug on the left. This will let you know if the problem is in one of your wires. If the side that is not working right changes you'll know the problem is in your plug wires
Compression test yes. 110 on one side 85 on other. The low compression side is the side firing. I don't know what a leak test is?
Sent from my SM-N910V using Tapatalk
You just found your problem. That motor is wore out or your tester is junk
Double check, and make sure slides are in carbs correct. Cut out faces airbox/filters.
sent from yo mammy house.
You ever check slides? Definitely time for a top end. Leak down tested a buddies bike that only seemed to run off one cylinder one time. I found out the front half were the cases meet was leaking.
Pull that motor apart, use ziplock bags and label everything, send crank and cylinders to shop of your choice. Farm and Sand Toys and Redline have a great name around here, I have used Precesion Powersports and they are good dudes as well. Have crank inspected, if it's good, true and weld it. The shop will tell you if you need a bore (most likely will) they will fix you up with pistons, gaskets, seals and such.
Depending on your wallet, your at the point to make some choices, could go 4 mill pretty easy especially if your crank is wasted, could port it and so on. Check the little things while its apart, kicker idler gear bushing, clutch and basket, pancake bearing, water pump and gear
First get a Clymer's if you don't already have one
