Just bought 99 banshee
Crossover tube? Sorry about all the questions in new to all this just trying to educate myself
Sent from my SM-N910V using Tapatalk
If you're running stock carbs, it's the tube that connects between them. Easy to see.
sent from yo mammy house.
Compression tested? Leak down tested? May as well get balls deep. Buy a clymers, and tools. Exhaust clogged up? Clogged pilot jet? Ohmed electrical components? Slides in correct?
Get busy, and start ruling shit out. If you bought it that cheap throw some money at it. Freshen shit up etc. You're going to have to do it sooner, or later. Nothing better then a piece of mind knowing it's right imo.
Yes it is installed guys. Checked that last night. I took mufflers off to eliminate the idea of them being clogged too. Still ran the same way. But what I noticed when I did that is the right pipe is blowing hot air meaning burning fuel. The left... Blowing cold air meaning no fuel burn and piston is just running up and down. I checked for sparks in both plugs out of motor. Both getting spark. So it seems it's only running on one cylinder
