Chain adjustment issue pics/ vid
you sure you're running a 14/41?
I went to 13front and had to grind the slot forward to shorten my chain to fit.
^^done the same myself, take the lower bolt out of your carrier and you can swing it up out of the way, you'll see slots in the swinger itself where the bottom bolt has some room to move back and forth depending on chain length, just remove some material from the front part of the slots and you will be able to remove a link and move your chain farther forward
Why are you stretching a chain that far after 10 hrs?
It also looks like the chain is digging into the side of the rear sprocket, chain may be toast.
When I fist got the chain I was in between links now since I removed some material now I have perfect chain tension no more clicking the chain was over 100 bucks it's a good pro taper x ring.
