Craig B Posted March 26, 2016 Report Share Posted March 26, 2016 (edited) I have some play in the steering stem [about 1/8 in.] You can move the handle bars forward & back. I bought a used steering stem clamp and am thinking if this is worn some it may be causing the extra play. Does the seal take away any of this play or is that just to keep dirt and water out?? Thanks. Edited March 26, 2016 by Craig B Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted March 26, 2016 Report Share Posted March 26, 2016 The seals aren't very big at all, barely bigger than the notch they fit in. I'd say the clamp is worn. Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 26, 2016 Report Share Posted March 26, 2016 ^^ yes. Replace the seals in the upper mount. Lots of grease Quote Link to comment Share on other sites More sharing options...
Craig B Posted March 26, 2016 Author Report Share Posted March 26, 2016 ^^ yes. Replace the seals in the upper mount. Lots of grease JD I didn't know the steering stem clamps get greased. Time for billet stem clamps with a grease fitting! Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 26, 2016 Report Share Posted March 26, 2016 JD I didn't know the steering stem clamps get greased. Time for billet stem clamps with a grease fitting! Just that split o ring area. I forget that company who makes /used to make the Delrin clamps. Savage 420 runs one. Has a grease zirt. Ima have to design one. Quote Link to comment Share on other sites More sharing options...
Craig B Posted March 26, 2016 Author Report Share Posted March 26, 2016 Looks like Mattoon has a billet one. http://www.ebay.com/itm/BILLET-YAMAHA-BANSHEE-POLISHED-STEERING-STEM-CLAMP-/222062038576 Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted March 26, 2016 Report Share Posted March 26, 2016 You can also sand down where the 2 pieces meet and it will tighten up on the stem. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted March 26, 2016 Report Share Posted March 26, 2016 Surf beat me to it Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted March 26, 2016 Report Share Posted March 26, 2016 omi is the steering stem clamp that savage420 runs. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 26, 2016 Report Share Posted March 26, 2016 omi is the steering stem clamp that savage420 runs.That. I run one to. Good shit. Worth it to get one. It's way bigger then stock grease zerk good seals no more play or squeak Quote Link to comment Share on other sites More sharing options...
Craig B Posted March 26, 2016 Author Report Share Posted March 26, 2016 omi is the steering stem clamp that savage420 runs. Thanks. I will check that Omi stem clamp out. Quote Link to comment Share on other sites More sharing options...
gcautosports Posted March 28, 2016 Report Share Posted March 28, 2016 Thanks. I will check that Omi stem clamp out.I had the same exact thing... turns out it was the tie rod that was bolted in to the a arm Quote Link to comment Share on other sites More sharing options...
gcautosports Posted March 28, 2016 Report Share Posted March 28, 2016 Turns out it was the tie rod, it wasnt bolted all the way onto the a arm* Quote Link to comment Share on other sites More sharing options...
