dsnellgrove241 Posted March 25, 2016 Report Share Posted March 25, 2016 Banshee was running fine went riding in the sand... went to ride again and when I started it the idle will go up and down and it was making weird popping noise almost like popcorn would backfire a couple of times and then die I did notice there was a little bit of sand in my carbs checked all the boots nothing was cracked or torn filter was still wet so I clean the carbs all out cleaned all the jets and it still doing this Thanks any help will be appreciated Sent from my SM-G928T using Tapatalk Quote Link to comment Share on other sites More sharing options...
dsnellgrove241 Posted March 25, 2016 Author Report Share Posted March 25, 2016 Banshee was running fine went riding in the sand... went to ride again and when I started it the idle will go up and down and it was making weird popping noise almost like popcorn would backfire a couple of times and then die I did notice there was a little bit of sand in my carbs checked all the boots nothing was cracked or torn filter was still wet so I clean the carbs all out cleaned all the jets and it still doing this Thanks any help will be appreciated Sent from my SM-G928T using Tapatalk Oh and I forgot when you give it gas it has like no power barely moves Sent from my SM-G928T using Tapatalk Quote Link to comment Share on other sites More sharing options...
hercalmighty Posted March 25, 2016 Report Share Posted March 25, 2016 Tors deleted? Do a leak down test Sent from my VS990 using Tapatalk Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 26, 2016 Report Share Posted March 26, 2016 Compression test buddy Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 26, 2016 Report Share Posted March 26, 2016 Banshee was running fine went riding in the sand... went to ride again and when I started it the idle will go up and down and it was making weird popping noise almost like popcorn would backfire a couple of times and then die I did notice there was a little bit of sand in my carbs checked all the boots nothing was cracked or torn filter was still wet so I clean the carbs all out cleaned all the jets and it still doing this Thanks any help will be appreciated Sent from my SM-G928T using Tapatalk If you verified carbs are clean, and cable and slides are free of sand, it's time to look for an air leak. I'm with JD on the compression test. Look for a variance from one cyl to the next. How do he plugs look? Quote Link to comment Share on other sites More sharing options...
dsnellgrove241 Posted March 26, 2016 Author Report Share Posted March 26, 2016 Put brand new plugs in it also the only thing I really changed besides the plugs was I went from 27.5 Pilots to 30's I am tearing it all down at the moment had a couple of buddies I ride with that also have Banshees and they said it sounds like a clogged pilot to them that would cause all these problems Sent from my SM-G928T using Tapatalk Quote Link to comment Share on other sites More sharing options...
dsnellgrove241 Posted March 26, 2016 Author Report Share Posted March 26, 2016 I'm going go back through clean all my Jets again thinking maybe a grain of sand might have got clogged in one of the pilots if this does not work I will try the leak down thank you guys for your help Sent from my SM-G928T using Tapatalk Quote Link to comment Share on other sites More sharing options...
dsnellgrove241 Posted March 26, 2016 Author Report Share Posted March 26, 2016 (edited) Okay this is where I am now got the sputtering and popping to stop no leaks but it is still backfiring and barely smoking out of one side and has absolutely no power I can't even make it up my driveway Sent from my SM-G928T using Tapatalk Edited March 26, 2016 by dsnellgrove241 Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 27, 2016 Report Share Posted March 27, 2016 Flywheel key sheared? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted March 27, 2016 Report Share Posted March 27, 2016 I did notice there was a little bit of sand in my carbs Where "in the carbs"? As in also in the engine... do a compression test Also did you get the slides back in the correct carbs? Quote Link to comment Share on other sites More sharing options...
guns4children Posted March 28, 2016 Report Share Posted March 28, 2016 Crossover tube installed? Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted March 28, 2016 Report Share Posted March 28, 2016 Compression test Pressure test Ohm out coil n plug caps installed Report back Are carb bowls on correct sides? Quote Link to comment Share on other sites More sharing options...
