crankshaft replacement question
Dan7305
I split my case this morning to get at the crank, bearings are shot, flywheel nut galled on its way off. I'm just getting a new crank.
Amazon has Hotrods crank, 2 day shipping. Dennis Kirk has a seal kit, but I didn't know about the transmission shaft keeper that hides behind the clutch basket while separating the case, and I managed to crack it. Where can I get that keeper? Is the dealer my only option? Where could I pull the part number for that?
For this crank, http://smile.amazon.com/Hot-Rods-4001-Crankshaft/dp/B000FTEVQK?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=ATVPDKIKX0DER
And this seal kit, https://www.denniskirk.com/cometic/bottom-end-gasket-kit-c7094be.p265747.prd/265747.sku
Is there anything else that I am going to need, besides that keeper? I'm thinking I should get a manual also, so I know torque specs.
Thanks in advance, I'm going to crawl in to bed, I'll check back when I get up this afternoon.
I can't even count the number of places on this list http://www.bansheehq.com/bansheehq-sponsors/that
can sell you the same things at the same prices and EVERYTHING else you will need in one order.
AND be able to give you expert technical advise before, during and after your purchase on BANSHEE's.
NEITHER of those two places (edit, 3) that you mentioned can do either of those things.
