Lowroll Posted March 22, 2016 Report Share Posted March 22, 2016 My Shee is a HJR hardcore MX ported 4 mil, Noss cool head and 23cc domes, 150 psi. chariot reed cages, chariot intakes with 35mm PWKs, +4 timing. I currently have FMF SST pipes and SST power core 2's on it. Pipes were bought before it had any motor work done. Now I find that it's somewhat difficult to ride in the woods and trails. The power comes on late, and it has crazy top end pull but it lacks on the bottom hard. I find myself constantly having to clutch in, rev and then clutch out to get back in the power again. I have geared up which has helped a lot but it still seems a little disappointing. 85% of my riding is woods and trails. The other 15% is WFO drag racing for fun which really shows my lack of bottom end power. Any thoughts? I've been considering PC's Quote Link to comment Share on other sites More sharing options...
gusto Posted March 22, 2016 Report Share Posted March 22, 2016 SLP! Quote Link to comment Share on other sites More sharing options...
guns4children Posted March 22, 2016 Report Share Posted March 22, 2016 If you bottom end is lacking with ssts you got more problems than pipes. Maybe Paul Turner's are worth a shot. Quote Link to comment Share on other sites More sharing options...
dailydrifter Posted March 22, 2016 Report Share Posted March 22, 2016 Go to a smaller carb Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 22, 2016 Report Share Posted March 22, 2016 (edited) Switch to 28mm PWK's and some SLP's, DMC, or Pro Circuits. Might be worth getting some different domes cut. Edited March 22, 2016 by trickedcarbine Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted March 23, 2016 Report Share Posted March 23, 2016 I would buy your 35mm ;-) Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted March 23, 2016 Report Share Posted March 23, 2016 Porting is prob to aggressive bu I like pro circuits Quote Link to comment Share on other sites More sharing options...
tdod101 Posted March 23, 2016 Report Share Posted March 23, 2016 Switch to 28mm PWK's and some SLP's, DMC, or Pro Circuits. Might be worth getting some different domes cut. Why are pwk's so popular? What's the diff between stock carbs and 28mm pwk? Quote Link to comment Share on other sites More sharing options...
Sandking Posted March 23, 2016 Report Share Posted March 23, 2016 Something else maybe off that set up should have plenty of low end, I had him do the same set up on two bikes in the last year and they both run great. Quote Link to comment Share on other sites More sharing options...
Sandking Posted March 23, 2016 Report Share Posted March 23, 2016 Why are pwk's so popular? What's the diff between stock carbs and 28mm pwk?Pwks are obviously larger but in all honesty the stock carbs work quit well to a point. Quote Link to comment Share on other sites More sharing options...
tdod101 Posted March 23, 2016 Report Share Posted March 23, 2016 So besides a little bit bigger carb not much difference? I like the eBay ad I saw that claims it increases HP by 10% Quote Link to comment Share on other sites More sharing options...
camp0429 Posted March 23, 2016 Report Share Posted March 23, 2016 I switched from stockers to PWK 28's over the winter, I've went on a couple small rides since, I can't believe the difference they made. My junk is your basic "bolt on" machine, ported stock cylinders, Pro Circuits, VF3's, UNI pod's. Yeah the stock carbs worked ok, I thought they were decent until I put these PWK's on. Throttle response is night and day difference. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 23, 2016 Report Share Posted March 23, 2016 Stockers are fine, but PWK's are superior. They are just so much more crisp. The flat slide helps with response as well. Quote Link to comment Share on other sites More sharing options...
tdod101 Posted March 23, 2016 Report Share Posted March 23, 2016 I switched from stockers to PWK 28's over the winter, I've went on a couple small rides since, I can't believe the difference they made. My junk is your basic "bolt on" machine, ported stock cylinders, Pro Circuits, VF3's, UNI pod's. Yeah the stock carbs worked ok, I thought they were decent until I put these PWK's on. Throttle response is night and day difference. Hmmm... Quote Link to comment Share on other sites More sharing options...
camp0429 Posted March 23, 2016 Report Share Posted March 23, 2016 Hmmm... They may not make a big difference on every Banshee, but I am damn sure impressed. They are a good match to my particular set up. Quote Link to comment Share on other sites More sharing options...
