02Banshee88 Posted March 21, 2016 Report Share Posted March 21, 2016 (edited) After I get my exhaust leak fixed, I am wanting to do some simple yet not to costly mods on my banshee to really wake it up. From talking to Kevin Galindo and Tyler Faith, they both think these are some good places to start... TORS Eliminator (just to save future headaches) V-Force 4 Reeds +4 Timing 20cc Domes Aftermarket Head I'm being told the 20cc domes will put me on the borderline for fuel where I need 93 Octane. What performance differences can I expect to see with these mods? Also, does anyone know any other simple mods I can make to add power that don't cost too much? I am on a limited budget right now but plan to put a 4mil crank in when I get the money. If I'll need to change anything with my jetting/etc. on the bike with these mods then that information would be greatly appreciated! Here is what I currently have in the bike and current riding conditions... Premix: 40:1 w/ Amsoil Dominator Pilot Jets: 30 Needle Jets: 4th Notch Main Jets: 280 Air Screw: 1.5 Turns Exhaust: FMF Fatty Gold Series w/ Powercore Silencer K&N Filter w/ no air box lid Current Temperature: 70-80 Elevation: 600 above sea level Edited March 21, 2016 by 02Banshee88 Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted March 21, 2016 Report Share Posted March 21, 2016 May as well ditch the air box and throw some pod filters on there too. 1 Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted March 21, 2016 Report Share Posted March 21, 2016 I would suggest the 21cc domes. I thought you were higher in elevation when I recommended 20cc domes. I'd recommend stockpiling parts to build a 4mil for when the current engine lets go (which will happen if you ride long enough). A 4mil can be done for as little as $1200 for new parts but can go up to as much as $5k for a fully built super cub/serval and supporting mods.Go ahead and start researching builders now. Call them and talk to them and see who you like the most. 1 Quote Link to comment Share on other sites More sharing options...
SandSlingerOR Posted March 22, 2016 Report Share Posted March 22, 2016 Vforce4 reeds $200 plus Timing plate $45 & under Pods $99 & under Shave or mill the stock head from Driveline cheaper then after market. I went off cascades prices which are priced higher then everyone else. That's easy mods & it'd be noticeable. Could he have his flywheel lightend as well? I have one in my play motor & it seems to be good for me. 1 Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted March 22, 2016 Report Share Posted March 22, 2016 I think I'd still recommend an aftermarket head for the ability to interchange domes. Sent from the whoops. 1 Quote Link to comment Share on other sites More sharing options...
02Banshee88 Posted March 22, 2016 Author Report Share Posted March 22, 2016 Thanks guys!!! Quote Link to comment Share on other sites More sharing options...
satts Posted March 23, 2016 Report Share Posted March 23, 2016 Pancake bearings a good idea ,so is checking waterpump and bearing Sent from my OUKITEL U2 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Time Machine Posted March 23, 2016 Report Share Posted March 23, 2016 (edited) You haven't said what your suspension is. I'm just like you, on a limited budget and want to build a stock cylinder 4 mil. I've talked it over with an engine builder and know what I'll do. But I've decided to focus first on getting a better suspension. It means putting off my 4 mil for another year, but I think it's worth the wait. I did all the mods you listed in your original post on the '94 I bought last year, then went after the suspension. +2+1 a arms, Elka Legacy shocks, all new tires and wheels, serviced the bearings and bushings, new sprockets and chain, etc. I bought an '01 in January, already has the mods you listed, but the stock suspension is old and tired. I just talked to Richard at House of Horsepower yesterday and will be sending him my rear shock to rebuild in a couple weeks. Then a new set of Elkas on front and maybe some new paddles on back to replace the old ones. Edited March 23, 2016 by Time Machine Quote Link to comment Share on other sites More sharing options...
@premiumsdd2 Posted March 23, 2016 Report Share Posted March 23, 2016 May as well ditch the air box and throw some pod filters on there too. this^^^ love my pods, so much more room under seat now too Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted March 23, 2016 Report Share Posted March 23, 2016 Suspension will make you faster in most cases than more horsepower. ISO purple BHQ hat. Sent from the whoops. Quote Link to comment Share on other sites More sharing options...
Oldskool83 Posted March 24, 2016 Report Share Posted March 24, 2016 (edited) Mull engineering shaved and re domed stock head will be good for good reliable power up. your jetting is good for those pipes. I have the same pipes and jetting on stock carbs. Predesign air filter and EHS open lid. You do not want to throw any dirt or mud onto pods...pods should only be used in dry only applications. Hell I never even liked pods on street bikes. Dropping down a tooth in the front or 2 will let you sing in the power band most times. Boyesen power reeds is all I have ever used with no issues. May not be the fastest but def funniest ones I've ridden has been to keep it simple. Stock I was 100% unhappy with the banshee's power, was a joke really. After these few simple mods I was a lot happier. Edited March 24, 2016 by Oldskool83 Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 26, 2016 Report Share Posted March 26, 2016 Screw the 4mil, not needed Mill stock head +4 timing Port stock reed cages or Vorce reeds 28mm PWK's / pod filters SLP pipes Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted March 26, 2016 Report Share Posted March 26, 2016 Screw the 4mil, not needed Mill stock head +4 timing Port stock reed cages or Vorce reeds 28mm PWK's / pod filters SLP pipes Hmm, seems like a site sponsor sells most of those in a package lol. I wouldn't put that much power on a stock crank. ISO purple BHQ hat. Sent from the whoops. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted March 26, 2016 Report Share Posted March 26, 2016 Hmm, seems like a site sponsor sells most of those in a package lol. I wouldn't put that much power on a stock crank. ISO purple BHQ hat. Sent from the whoops. I've put more than that on a stock unwelded crank, it will probably be fine for awhile. It's always good to let people know they are on barrowed time though. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 26, 2016 Report Share Posted March 26, 2016 (edited) Hmm, seems like a site sponsor sells most of those in a package lol. I wouldn't put that much power on a stock crank. ISO purple BHQ hat. Sent from the whoops. Stock cranks if welded are holding up in 100hp alky drag motors for a few seasons. Edited March 26, 2016 by trickedcarbine Quote Link to comment Share on other sites More sharing options...
