Frustrated/Rant
tdod101
Put the damn thing together and run it! Sick of the "if you don't do a leak down your shit will just immediately blow up" routine.
Take your time. Use good parts and sealant. Torque important stuff. Ride.
Speaking my mind. If it starts revving all weird, then check. But if someone is using quality gaskets and clean flat surfaces, taking their time, it should be evident that it is ok. Some folks just do everything the hard way so i guess those same folks needed the extra insurance that they haven't fucked it up. If you are truly capable of working on these things you should be able to feel when things are/arend going together properly.
  • Like 2
The tester is on the way. I shipped it to him yesterday.
I've put together many motors with no test. None have leaked. But really, what's the extra 6.5 minutes to guarntee it's correct Before you install.
If you find out its leaking between the cases now you need to tear it back down and start over.
Something those 6 minutes could've saved you. Shit happens sometimes. Done it sp many times your auto pilot just misses something silly.
