tdod101 Posted March 19, 2016 Report Posted March 19, 2016 (edited) Both my plugs are the same colour. But the right one is more wet with oil. Not a lot or anything but enough I know something is off. My exhaust header is a little loose on the left side as well where it connects to exhaust port, and seems to drip black stuff a little. Maybe that's the problem. I'll admit. The T5's have seen better days. Motor is a 4 mil dune port. Edited March 19, 2016 by tdod101 Quote
trickedcarbine Posted March 19, 2016 Report Posted March 19, 2016 Which side is off, stator or clutch side? Carbs synced? No air leaks? Quote
tdod101 Posted March 19, 2016 Author Report Posted March 19, 2016 (edited) Which side is off, stator or clutch side? Carbs synced? No air leaks?Carbs synced, no air leaks. Electrical? Clutch side is the wet side. I'm also thinking I should swap out the rubber carb boots and just get a single piece billet from modquad or something. Edited March 19, 2016 by tdod101 Quote
trickedcarbine Posted March 19, 2016 Report Posted March 19, 2016 No on any ModQuad parts. Plugs gapped evenly? Plug boots are ok? Both cylinders are in good shape and compression testing evenly? No slight coolant leak? Quote
tdod101 Posted March 19, 2016 Author Report Posted March 19, 2016 No on any ModQuad parts. Plugs gapped evenly? Plug boots are ok? Both cylinders are in good shape and compression testing evenly? No slight coolant leak? yes, yes, yes. no Quote
