slg2021 Posted March 17, 2016 Report Share Posted March 17, 2016 I have the stock nissin rear break caliper, but it is leaking and I can find every gasket for it except the rear paper on the parking break... I was wondering where I could get it or if the is a part number Quote Link to comment Share on other sites More sharing options...
Phelps Posted March 17, 2016 Report Share Posted March 17, 2016 Uses a oring inside the caliper no need for a gasket Quote Link to comment Share on other sites More sharing options...
slg2021 Posted March 17, 2016 Author Report Share Posted March 17, 2016 so i could just clean off the old gasket and put a new o ring? and that should stop my leaking problem? Quote Link to comment Share on other sites More sharing options...
Phelps Posted March 17, 2016 Report Share Posted March 17, 2016 Yes 1 Quote Link to comment Share on other sites More sharing options...
cjc Posted March 18, 2016 Report Share Posted March 18, 2016 so i could just clean off the old gasket and put a new o ring? and that should stop my leaking problem? yes as long as the piston shaft is not corroded or pitted, if it is it will eat the new Oring. if the piston shaft is bad you will need to replace the piston ,or you can cut it off and tap the hole for a pipe plug. Quote Link to comment Share on other sites More sharing options...
