braptor52 Posted March 16, 2016 Author Report Share Posted March 16, 2016 I never checked squish when it had the 17cc setup and ported cylinders. I should have for a reference. I also didn't look at how the head seated on the cylinders. Didn't even cross my mind. The old cylinders I believed to be oem with port work. My current cylinders are aftermarket but stock ports and bore. I did not test fit the cylinders to head prior to installation. Just slid new cylinders over existing studs in case. Torqued. Then installed head studs. Then installed head with rubber mallet. Was snug going on. Then torqued. I measured squish through spark plug hole with .062 solder and it was a little difficult to measure the solder since it didn't get compressed completely flat. Was thinkin bout using .112 solder but thought it may be too thick. left cylinder I was getting .055 and right cylinder I would get .058 again this was through spark plug hole so not 100% accurate. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 16, 2016 Report Share Posted March 16, 2016 Are those niche cylinders? Quote Link to comment Share on other sites More sharing options...
braptor52 Posted March 16, 2016 Author Report Share Posted March 16, 2016 I think they read Niche. It's either niche or namura but I think they make Pistons Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted March 16, 2016 Report Share Posted March 16, 2016 Call them asap, let them know what your issue is. Maybe they had a bad batch of studs misaligned. In the mean time, try another head. If a different head does the same then you know it's the cylinders. If the other head is fine, you get where I'm going. Quote Link to comment Share on other sites More sharing options...
braptor52 Posted March 16, 2016 Author Report Share Posted March 16, 2016 (edited) That's the kit I bought and have on my bike right now. I'm gunna disassemble tonight and try seeing if I can get the head to fit better. Maybe that will change my compression. When I first got these cylinders I sent one back cause it had lots of left over casting flash in ports and I didn't want to port them at the time cause I just wanted small stock ports and trying to get the bike assembled and rideable without going all out and spending more money on port work. The funny thing is I saw the same kit from same supplier for more money so it makes me wonder why the kit I bought was cheaper. Really was unhappy with overall quality. Gasket set was opened and repackaged. Also I could tell base gasket in the kit was previously installed but not torqued down. Sent from my iPhone using Tapatalk Edited March 16, 2016 by braptor52 Quote Link to comment Share on other sites More sharing options...
braptor52 Posted March 16, 2016 Author Report Share Posted March 16, 2016 (edited) Well just got off the phone with AZ racing in Ontario California and the gentleman I spoke with didn't hesitate when I told him that I had fitment issues with the studs and misalignment with the head. Said I can send them back. Definitely remember removing the head from the old oem cylinders with ease and I know this time it's going to be difficult to remove due to the fact that I had to tap the head on over the studs during install. This leads me to think there is a definite issue with the cylinders and they're stud holes. Sent from my iPhone using Tapatalk Edited March 16, 2016 by braptor52 Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted March 16, 2016 Report Share Posted March 16, 2016 It might make it easier to loosen the head nuts then remove the base cylinder nuts first, and free it up some. Quote Link to comment Share on other sites More sharing options...
braptor52 Posted March 16, 2016 Author Report Share Posted March 16, 2016 Good idea then hopefully I won't have to pry on anything to lift it off. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted March 16, 2016 Report Share Posted March 16, 2016 while your changing it all up put a noss dome style head on it or a cut stocker from Driveline Performance...you`ve just avoided a meltdown by not running it lol Quote Link to comment Share on other sites More sharing options...
braptor52 Posted March 16, 2016 Author Report Share Posted March 16, 2016 Yea what about a pro design? Noss seems to be the best from what I've read Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted March 16, 2016 Report Share Posted March 16, 2016 I like them both over the others Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted March 16, 2016 Report Share Posted March 16, 2016 domes are compatible between both brands i think as well as cascade ...steer away from modquad Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted March 16, 2016 Report Share Posted March 16, 2016 domes are compatible between both brands i think as well as cascade ...steer away from modquadDoesn't cascade sell pro desighn? Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted March 16, 2016 Report Share Posted March 16, 2016 i dont really know i thought they made thier own Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted March 16, 2016 Report Share Posted March 16, 2016 you are correct Quote Link to comment Share on other sites More sharing options...
