Jetting help after porting
Rebuilt a new engine and now runs poor.
My old engine had T5 pipes, Vforce 3 reeds, pod filters, +4 timing bored out .040,135 psi compression, stock carbs. This engine ran great with 280 main and needle in 4th position
Rebuilt a new engine using all the old parts except I'm now running ported cylinders and 185 psi compression. I changed the main jet to 330 and it ran terrible. Slowly worked my way down to a 290 with the needle in the second position and it now runs better, but from 1/4 throttlet to 1/2 throttle it still seems rich.
If I dump the clutch with the engine in the higher rpm it takes off great.
Is it possible my jet sizes stayed the same going from stock port cylinders to ported cylinders? Any help on what I need to do to get rid of the dead spot just above idle?
Edited by sand-paddles
