got1banshee Posted December 2, 2003 Report Share Posted December 2, 2003 What is the diff in performance from the shorter swimg arm and the longer one? Wouldn't it be harder to realy get on it and keep the front end down with a shorter swing arm? Its hard enough to keep my front end down now in 1-3 with the stock arm. I was thinking about getting a 4" longer swing. Would that be a bad idea? I am building a Vito's 404 big bore stroker moter for it right now. What should I do? Quote Link to comment Share on other sites More sharing options...
Banchetta Posted December 2, 2003 Report Share Posted December 2, 2003 Do you run paddles or knobbies??? Quote Link to comment Share on other sites More sharing options...
Yamaha350T Posted December 2, 2003 Report Share Posted December 2, 2003 a -2 swingarm doesnt make a banshee wheelie like you think it would, it just handles much better. If your riding in dunes do an extended, or if you hill climb. I'm going to be running a -2 climbing and see how it goes. A +4 would make a shee fell like a limo in a pit. Quote Link to comment Share on other sites More sharing options...
got1banshee Posted December 3, 2003 Author Report Share Posted December 3, 2003 I use pabbles in the sand but I run more in the trails and field Quote Link to comment Share on other sites More sharing options...
Yamaha350T Posted December 5, 2003 Report Share Posted December 5, 2003 if you ride trails and fields, there is no need for a +4, try a -2, its real easy to have done, especially if you have a friend thats a welder Quote Link to comment Share on other sites More sharing options...
Blue Duece Posted December 5, 2003 Report Share Posted December 5, 2003 What is the diff in performance from the shorter swimg arm and the longer one? Wouldn't it be harder to realy get on it and keep the front end down with a shorter swing arm? Its hard enough to keep my front end down now in 1-3 with the stock arm. I was thinking about getting a 4" longer swing. Would that be a bad idea? I am building a Vito's 404 big bore stroker moter for it right now. What should I do? if you cant keep your front end down gear it taller, you'll go faster, the -2 has so many benifits, it would take a while to list them all..... Quote Link to comment Share on other sites More sharing options...
Yamaha350T Posted December 5, 2003 Report Share Posted December 5, 2003 -2 is definitely the way to go Quote Link to comment Share on other sites More sharing options...
txblueshee Posted December 5, 2003 Report Share Posted December 5, 2003 Go to the reviews section and click on -2.5 ride review... I garantee there's more than enough info in there. Mike Quote Link to comment Share on other sites More sharing options...
banshee tuner Posted December 7, 2003 Report Share Posted December 7, 2003 Im running 15-41 gearing, what gear are you running with -2 swingarm Quote Link to comment Share on other sites More sharing options...
Yamaha350T Posted December 13, 2003 Report Share Posted December 13, 2003 Do you have good low end with 15 41 gearing? I dont think you would. You should try a 13 41 setup with 21 inch tires, its a mint setup. I run 14 40 with 22 inchers, but im going to get some 21s, and I ordered a 13 tooth front sprocket. A 40 tooth rear is just a Blaster sprocket, in case your gunna get one. Quote Link to comment Share on other sites More sharing options...
banshee2sick Posted December 13, 2003 Report Share Posted December 13, 2003 I would have to agree about the -2. I had MrMatt cut mine down, and I couldnt say enough good things about his work or the handling enhancement of the shorter swingarm. Quote Link to comment Share on other sites More sharing options...
Blue Duece Posted December 16, 2003 Report Share Posted December 16, 2003 Im running 15-41 gearing, what gear are you running with -2 swingarm im running a 15/40.....most guys riding in dirt like the little taller 15, it makes your bike pull a little nicer than a 14.....i always try to find the spot in between lift and accelration, i want my gears stretched but i also want my front end to rise for ruts and whoops and such also your mods have a lot to do with how well your bike pulls those taller gears, the shorter swing arm helps get what ever you have to the ground, as well as handling better it also changes the weight distribution over the chassis, ive never ridden a shee with a -2 swing arm and stock a-arms though, it really works well when you have a aftermarket aarm thats forward an inch or two Quote Link to comment Share on other sites More sharing options...
Dextreme Posted December 19, 2003 Report Share Posted December 19, 2003 If you are building a 404 and ride in the dunes, I can't see why a shortened swing arm is going to benefit. My opinion is to go with the +4. Here's some pics of mine when I lengthed it... You can see I drilled it out for plug welds and reinforced the inside: http://www.sandlakeduners.com/images/4over.jpg All done and ready for install: http://www.sandlakeduners.com/images/4over2.jpg Quote Link to comment Share on other sites More sharing options...
Banchetta Posted December 19, 2003 Report Share Posted December 19, 2003 Im running 15-41 gearing, what gear are you running with -2 swingarm im running a 15/40.....most guys riding in dirt like the little taller 15, it makes your bike pull a little nicer than a 14.....i always try to find the spot in between lift and accelration, i want my gears stretched but i also want my front end to rise for ruts and whoops and such also your mods have a lot to do with how well your bike pulls those taller gears, the shorter swing arm helps get what ever you have to the ground, as well as handling better it also changes the weight distribution over the chassis, ive never ridden a shee with a -2 swing arm and stock a-arms though, it really works well when you have a aftermarket aarm thats forward an inch or two I ran my stock arms for a month or two before I got my 2+2's from Gary...Didn't really notice much difference for traction or shortness, ...Did notice a difference for powersliding w/ the wider stance though.... .. the best improvement was the front bumper not bottoming on steep jumps and hills.... Quote Link to comment Share on other sites More sharing options...
NAXbansheeman11 Posted December 19, 2003 Report Share Posted December 19, 2003 Well i may be running my bike in xc thise season and i have a =1 lsr round house and I was going to get a -1 from gary cuz that is the size my buddy runs . would a -2 be better would i still be able to run 22 inch tire? Quote Link to comment Share on other sites More sharing options...
