T5 exhaust
No air box , K&N filters
Carbon fiber reeds
Stock piston size
Noss cool head with 22cc domes
Keihin 28mm pwk flat chrome slide carbs
I'm at sea level
Tores removed parking brake removed
45pilot
150main
Hope that's all info needed , right now there is 45 pilot and 150main . she won't even idol , when it fires it bogs right out . carbs / reeds / top end /cool head , are all brand new . It has blue spark and fresh gas .wondering if its a jetting issue . and what sizes you guys recommend . figure I will start there with the carbs hopefully fixes the issue .
Listen I'm having the some problem. I'm going to try some 280 mains. I would start my bike and it won't idle. It can also be the air screw. I'll have to mess with that screw some more.
Let me know how you make out . I think my issue might be deeper than just a rejet . I never heard this bike run . I got it in pieces a year ago from a buddy and put it all back together from ground up . I didn't cut any corners , so I know the build is solid .just want to make sure my fuel delivery is 100% and work my way out from there .
