zachwells229x Posted February 28, 2016 Report Share Posted February 28, 2016 Hi I have an 02 shee with Tors delete kit and basic mods cool heads pipes reeds blah blah blah, I have no spark I had the coil bench tested and it came back with .4 ohms.... .02 higher than normal? I'm about to give up on the thing any help??? Sent from my Z812 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 28, 2016 Report Share Posted February 28, 2016 look over all the wires for mice chewing, since it's been sitting too. Especially plug wires, they like those. Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 3, 2016 Report Share Posted March 3, 2016 1. Swap CDI with known working unit. 2. Ohm stator 3. Set pickup gap 4. Make sure ground wire (in the back near CDI and voltage regulator) has a clean, bare metal surface that it is secured to. 5. Order a new harness from us to rule out all the BS. http://www.jdscustoms.com/product/oem-length-drag-cut-wire-harness/ Quote Link to comment Share on other sites More sharing options...
