Gemeiner Posted February 26, 2016 Report Share Posted February 26, 2016 Weathers gotten warmer and yesterday while riding I noticed a dead spot in 4th gear at WOT. It'll go from the normal high pitched to a bogging brrrrrrrr sound. Which is weird to me because I'd be expecting a lean sound. Never noticed it over the winter. Same jets though. And I resynced my carbs because they were a little off. Maybe my main jets are too big or too small? Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted February 26, 2016 Report Share Posted February 26, 2016 Main jets are too big. Cold temps means bigger, or richer jets, and warm temps means smaller, or leaner jets. 1 Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 26, 2016 Report Share Posted February 26, 2016 Down and dirty test, when it starts to bog, pull choke out. If worse, you're rich. If better you're lean, possible air leak. 1 Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted February 26, 2016 Author Report Share Posted February 26, 2016 Think you're right about the jets. It uses 310s perfectly in the desert at sea level so I put 270s for 4000 feet where I live. It's 30 degrees at night and 80 in the day rt now and I ride all day long so jettings kind of a pain. It only seems to act up in 4th. But it's definitely a bogging sound not a lean sound. I'll ride it today and see what it does. Couldn't open it up last night after I synced the carbs, too dark on the trails. Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 26, 2016 Report Share Posted February 26, 2016 Clean the air filter...had it happen to me. Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted February 26, 2016 Author Report Share Posted February 26, 2016 Ya that's the only gear it bogs but I didn't get into 5th. But 3rd WOT sounded a little off but it didn't bog Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted February 26, 2016 Author Report Share Posted February 26, 2016 Air filter was just cleaned too Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 26, 2016 Report Share Posted February 26, 2016 Did you over oil it? Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted February 26, 2016 Author Report Share Posted February 26, 2016 Well that's fuckin why. Son put some unmixed gas in. Lucky I didn't fuck something up Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted February 26, 2016 Author Report Share Posted February 26, 2016 Just looked at the gas Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted February 26, 2016 Author Report Share Posted February 26, 2016 Lucky It was only a gallon or 2 Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
uman1030 Posted February 26, 2016 Report Share Posted February 26, 2016 Lucky It was only a gallon or 2 Sent from my SM-N920V using Tapatalk better compression check that thing if you been running with little to no oil! Quote Link to comment Share on other sites More sharing options...
Gemeiner Posted February 27, 2016 Author Report Share Posted February 27, 2016 It had half a tank or more of mixed gas. I use amsoil dominator 32:1 anyways suppose to be like 40:1 so the gallon or 2 of unmixed just made it run rich. Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
