Leakdown Question
Mattchev
What's your elevation?
I'd try some 320 mains to start with.  You may need smaller, but that's where most tend to end up with that setup.  May want to order some 27.5 pilots to be safe.
im sea level. had a similar banshee with 27.5 and 290s that ran pretty perfect. so ill prob end up somewhere around there.
  • Like 1
I THINK the smoke was the new oil burning off..
I don't BELIEVE you have a coolant leak..
Look at your carbs.. Did you clean them or disassemble them in ANY way? Did you get the crossover tube between the carbs on correctly?
did carb rebuild, cleaned them all out real good..jets and everything. crossover tube is there.  i thought it was just oil burning off also, but the bike didnt wanna rev high or idle, and the white smoke didnt let up. stayed pretty thick the whole time it was running.  i did new crank seals on both sides too which i heard is known for smokey exhaust like that when they go bad.
