Banshee sounds weird
Owlbert
Yeah it started acting up last weekend it was like the throttle was stuck so I shut it off and bumped the throttle a couple times and it was fine for awhile and then it did it again a little while late so I did the same thing then it ran fine for the rest of the day and I parked it in the garage and went to start it yesterday and that's when it sounded weird
  • 2 weeks later...
had this problem after i cut my parking brake. a friend of mine was dicking around with the wires but i cant remember right off the bat when he touched the wires together or pulled them apart. it ran perfect. had same problems, wouldnt idle, ran crappy. felt like the throttle was stuck closed. (not stuck open) check wiring if your still having problems.
