mushman420 Posted February 25, 2016 Report Share Posted February 25, 2016 I have a 1998 banshee with stock cylinders and pistons. It has, Boost bottle Fmf gold series with silencers Dual k&n I'm at 2000 feet above sea level Days from 40 to 90 degrees I'm running 290 main and 30 pilot and it wont idle or even rev when i hit the throttle. It will just fire. I was thinking of going to 226 main and 31? or 32? for the pilot. I wanted someones opinion on that. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 25, 2016 Report Share Posted February 25, 2016 First, ditch the bottle. It WILL crack the carb boots. What's air screw at? What do plugs look like? Spark? TORS eliminated? Parking brake? Has this thing ever ran, or has it gotten worse? Ever do a plug chop/read? Last time you actually did some maintenance? The jet sizes you mentioned do not exist. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 25, 2016 Report Share Posted February 25, 2016 It's not your jetting Quote Link to comment Share on other sites More sharing options...
mushman420 Posted February 25, 2016 Author Report Share Posted February 25, 2016 fursure ill grab by buddys stock crossover the air screws are both at 1 1/2 turns out. plugs are new but they are wet I have spark TORS and parking break is eliminated. it ran flawlessly until a shop talked me into getting v force 4 reeds i had vf2 before. so i did some research and rejetting was a big thing maintenance wise i do oil changes every first of the month. radiator fluid i change every couple few internal wise like top end or bottom i havent. compression is around 120 on both heads what about at 220 main and 32.5 pilot? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 25, 2016 Report Share Posted February 25, 2016 what about at 220 main and 32.5 pilot? NO check for air leak Choke tube in place between carbs? Quote Link to comment Share on other sites More sharing options...
mushman420 Posted February 25, 2016 Author Report Share Posted February 25, 2016 no leaks and yes Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 25, 2016 Report Share Posted February 25, 2016 Has it not run since the reed change? That's a super common spot for an air leak. Quote Link to comment Share on other sites More sharing options...
mushman420 Posted February 25, 2016 Author Report Share Posted February 25, 2016 (edited) yea it hasnt and their is no leak. but lets say there was... how would i go about fixing it? do i just put another gasket on? Edited February 25, 2016 by mushman420 Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 25, 2016 Report Share Posted February 25, 2016 no need since it passed a leak down test. Quote Link to comment Share on other sites More sharing options...
mushman420 Posted February 25, 2016 Author Report Share Posted February 25, 2016 i dont know where to go from here. i have a set of keihns but the jets are all off on those too. i know the banshee idles with them tho but bogs from half to full throttle. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 25, 2016 Report Share Posted February 25, 2016 So it held 6psi for 6 minutes? Quote Link to comment Share on other sites More sharing options...
mushman420 Posted February 25, 2016 Author Report Share Posted February 25, 2016 i was told 8 for 8 but yea it held Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 25, 2016 Report Share Posted February 25, 2016 Well dang, don't know what to tell you, but your 290/30 jetting ain't the problem. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 25, 2016 Report Share Posted February 25, 2016 Slides in the correct carbs? Quote Link to comment Share on other sites More sharing options...
mushman420 Posted February 25, 2016 Author Report Share Posted February 25, 2016 welp guess it powder coating time while im down Quote Link to comment Share on other sites More sharing options...
