dailydrifter Posted February 24, 2016 Report Share Posted February 24, 2016 I'm rebuilding a fireball swingarm and need to know what bearings to get. For the pivot tube it looks like stock bearings will work but for the roundhouse bearings I'm not sure what to get. Can anyone point me in the right direction. It's a 35mm carrier. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 27, 2016 Report Share Posted February 27, 2016 See what brand the actual carrier is and check with them. I believe different companies used different bearings. Or get the part numbers off the bearing themselves. Quote Link to comment Share on other sites More sharing options...
87sheerips Posted March 3, 2016 Report Share Posted March 3, 2016 I'm rebuilding a fireball swingarm and need to know what bearings to get. For the pivot tube it looks like stock bearings will work but for the roundhouse bearings I'm not sure what to get. Can anyone point me in the right direction. It's a 35mm carrier. Pivot tube Kit: http://www.jdscustoms.com/product/pivot-works-swing-arm-kit-yamaha-atv/ Get a 35mm bearing carrier from eBay.... A boss or something if you need cheap.. If you want to do it right, get a JJ&A bearing carrier. Usually the cost of new will justify NOT servicing an old one IMO. Quote Link to comment Share on other sites More sharing options...
