02Banshee88 Posted February 23, 2016 Report Share Posted February 23, 2016 Okay so I'm simply needing to know what's the best premix ratio of gas and oil to have the proper gas/oil/air mix running in my Banshee based on my jetting and mods. Right now it's running Amsoil Dominator but I'm hearing from several people that the recommended 50:1 premix is not correct. HELP PLEASE! These are my mods and jet settings... - K&N High Performance Air Filter - Air box with no lid - FMF Gold Series Fatty w/ Powercore Silencers - Pilot jets: 30 (may be switched to 27.5 this week) - Needle jets: 4th notch - Main jets: 290 Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted February 23, 2016 Report Share Posted February 23, 2016 With good oil, no problem running 50/1. If your bike was jetted at 50/1 stay at 50/1 Envoyé de mon GT-P5113 en utilisant Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted February 23, 2016 Report Share Posted February 23, 2016 It's always better to pick a good ratio (32:1 40:1 50:1 depending on oil of choice), then jet it afterwards. 1 Quote Link to comment Share on other sites More sharing options...
02Banshee88 Posted February 23, 2016 Author Report Share Posted February 23, 2016 (edited) Got it. Thanks! Edited February 23, 2016 by 02Banshee88 Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 24, 2016 Report Share Posted February 24, 2016 Coming from a different point of view I can always tell a bike that's had 40-1&50-1 ratios run through them . IMO get your power somewhere else and give em oil 1 Quote Link to comment Share on other sites More sharing options...
02Banshee88 Posted February 24, 2016 Author Report Share Posted February 24, 2016 Coming from a different point of view I can always tell a bike that's had 40-1&50-1 ratios run through them . IMO get your power somewhere else and give em oil So you believe it wouldn't hurt to run 40:1 even with my current jetting? That makes sense because my buddy Tyler on here told me that honestly the power gain/loss is negligible with 50:1 premix and it's usually better to run 32:1 or 40:1 depending on how the bike is set up. Quote Link to comment Share on other sites More sharing options...
Keno Posted February 24, 2016 Report Share Posted February 24, 2016 You don't gain power by adding less oil. It is actually possible to increase power with more oil because of better ring sealing. 40:1 is pretty middle of the road and what I imagine most people run. If you add more oil your jetting becomes effectively leaner and if you add less oil your jetting becomes effectively richer. Your jetting has no effect on what ratio of oil to run. 1 Quote Link to comment Share on other sites More sharing options...
Keno Posted February 24, 2016 Report Share Posted February 24, 2016 (edited) You don't gain power by adding less oil. It is actually possible to increase power with more oil because of better ring sealing. 40:1 is pretty middle of the road and what I imagine most people run. If you add more oil your jetting becomes effectively leaner and if you add less oil your jetting becomes effectively richer. Your jetting has no effect on what ratio of oil to run. This was good advise. Listen to him. With good oil, no problem running 50/1. If your bike was jetted at 50/1 stay at 50/1Envoyé de mon GT-P5113 en utilisant Tapatalk edit: I somehow double posted. Sorry Edited February 24, 2016 by Keno Quote Link to comment Share on other sites More sharing options...
02Banshee88 Posted February 24, 2016 Author Report Share Posted February 24, 2016 Okay thanks. Quote Link to comment Share on other sites More sharing options...
