Picking up another banshee.
Picking up this banshee next saturday and have some questions.
Some thing will be doing later on after a week or two.
+2+1 a arms
+2 axle
+1 swing arm round house
yfz450 front brakes
Shocks rebuilt or buy new.
All new powder coating
bigger carbs
differnt pipes
other billet parts and lots of cleaning and powdercoating.
Cory wiring harness
Will be trashing Boost bottle.
Front smoothie paddles
skat trak hauler 10 paddles.
Owner states it is a
Aluminum water,pump gears
High output coil with the dyno tek cdi box
Works shocks aftermarket rear axel and bearnings Rentha sprockets and o-ring chain
Frame blasted Freash oem paint on frame
Tors delete on carbs with idles screws installed Jetted carb for build
Vforce 3 reeds with spacer
Ricky stator advanced +4
4 mill crank .80 bore on cylinders dune port
WSM pistons and rings
Pro design cool head
Full fmf exhaust.
He says he only has two tanks of gas gone thourgh motor and it dynoed at 90 hp on vp115 but can run 91, Hes gonna get back to me with dome size and proof of compression test later tonight.
Will only be rode at LSOK, hopefully have everything ready to go before the BHQ ride.
Anyone have some other ideas what to do or have any parts, pm the price and pics thanks!
Edited by Wadester555
That is what i was thinking, part of reason why im posting this, wondering while im there if i should take off the head and make sure the pistons look new like he said they were and only 2 tanks of fuel, but there wouldnt be any way to check if it is a aftermarket crank with just the head off would their?
You can measure the stroke through the spark plug hole with like a pencil, and you can look at the pistons by just pulling the pipes, if you feel the need to.
That is what i was thinking to and i dont really care how much hp it makes so doesnt matter,but the fact hes lying about the hp makes me think the crankshaft will be stock and has more than 2 tanks of fuel ran though it.
If he built it, he's bullshitting about the power, but if it was sold to him like this, then he's prolly regurgitating whatever stupid shit the person sold it to him told him. Defiantly check compression, he might not let you pull the pipes or head to check stroke, or condition of cylinders. There's a thread on here about what to look for when buying a used bike. Find it, read it, live that shit. And of course, if the price is right, might be worth the risk. I'd feel comfortable at about $1500 for this bike. It's got some nice stuff on it. If compression checks out, and everything else looks good, buy it, and rebuild when it blows up.
