TopGear007 Posted February 20, 2016 Report Share Posted February 20, 2016 I was out for a long ride I was going fast for a long period of time and all of a sudden it starting going full throttle when I stopped in nuteral it kept doing the same thing loud what did I do did it blow up or how do I fix it thanks guys Quote Link to comment Share on other sites More sharing options...
Phelps Posted February 20, 2016 Report Share Posted February 20, 2016 leaned it out . probably toast. id do a compression test but i got a feeling you might just start tearing it down. they're not designed to be held wot for long periods of time without proper jetting. Quote Link to comment Share on other sites More sharing options...
TopGear007 Posted February 20, 2016 Author Report Share Posted February 20, 2016 leaned it out . probably toast. id do a compression test but i got a feeling you might just start tearing it down. they're not designed to be held wot for long periods of time without proper jetting. Quote Link to comment Share on other sites More sharing options...
TopGear007 Posted February 20, 2016 Author Report Share Posted February 20, 2016 I found the air leak the cap on the carb was off and I put it back on Quote Link to comment Share on other sites More sharing options...
TopGear007 Posted February 20, 2016 Author Report Share Posted February 20, 2016 Would it run back to normal since I fixed the air leak Quote Link to comment Share on other sites More sharing options...
registered user Posted February 20, 2016 Report Share Posted February 20, 2016 dynamite in the gas tank bro. be sure to stand close when it explodes Quote Link to comment Share on other sites More sharing options...
Craig B Posted February 20, 2016 Report Share Posted February 20, 2016 Would it run back to normal since I fixed the air leak Yes. I would do a compression test to be safe. Quote Link to comment Share on other sites More sharing options...
oldskool Posted February 20, 2016 Report Share Posted February 20, 2016 As said, check your compression. See if spark plugs are still tight. Plugs will tend to back out in dangerously lean conditions Quote Link to comment Share on other sites More sharing options...
oldskool Posted February 20, 2016 Report Share Posted February 20, 2016 dynamite in the gas tank bro. be sure to stand close when it explodes Have you ever heard that pop sound? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 20, 2016 Report Share Posted February 20, 2016 Air leak. With a runaway engine hold brake, shift into 2nd or higher, dump clutch. Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted February 20, 2016 Report Share Posted February 20, 2016 Would it run back to normal since I fixed the air leak It depends if you didn't do any damage while the cap was loose, as suggested be certain and a compression test to be sure! Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted February 20, 2016 Report Share Posted February 20, 2016 how long was it running like this Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 21, 2016 Report Share Posted February 21, 2016 Mike seen first hand what a loose cap can cause, he watched a brand new 4 mill motor eat itself from a carb top problem Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted February 21, 2016 Report Share Posted February 21, 2016 Sad but true! Maybe 10 min on the motor, video taped him going WOT, and in less than 5 min a brand new 4mil just built ate itself up! Quote Link to comment Share on other sites More sharing options...
