mgk2031 Posted February 17, 2016 Report Share Posted February 17, 2016 Hey Guys, Just picked up a new 06 Special Edition from nevada but live in florida and need some pointers on how to re-jet it. I have looked in the thread for jetting and have not really found much with my specific mods so I was hoping I could get some insight. My shee has stock motor with just vforce 4 reeds, t5 exhuast, k&n pods with outerwears. Stock Carbs and No porting. Elevation is sea level and operating temp is about from 70 - 90+. I run klotz benol at 32:1 on 93 octane if that has any effect as well. Any help is greatly appreciated! Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 17, 2016 Report Share Posted February 17, 2016 What was the elevation in Nevada where it came from? Quote Link to comment Share on other sites More sharing options...
Jogon30 Posted February 17, 2016 Report Share Posted February 17, 2016 You should be around 370 main jet and 25 pilot Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted February 17, 2016 Report Share Posted February 17, 2016 You should be around 370 main jet and 25 pilotMeh, that sounds way off but that's just my .02 1 Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted February 17, 2016 Report Share Posted February 17, 2016 You should be around 370 main jet and 25 pilotWTF IN THE MOTHER FUCK!? Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 17, 2016 Report Share Posted February 17, 2016 290-300 main jet ,27.5 , toomey needles 3rd clip 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 17, 2016 Report Share Posted February 17, 2016 You should be around 370 main jet and 25 pilotThat would be so friggin rich up top and over heat a motor lean on the pilot. Quote Link to comment Share on other sites More sharing options...
Ronaldkrause Posted February 17, 2016 Report Share Posted February 17, 2016 If i were you i would go into a shop that knows alot about banshees and tou. An tell them that all your mods are and they can gibe you a pretty accurate size Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 17, 2016 Report Share Posted February 17, 2016 If i were you i would go into a shop that knows alot about banshees and tou. An tell them that all your mods are and they can gibe you a pretty accurate size Sent from my iPhone using Tapatalk Shitty advice right here /\/\ Have read more of places fucking shit up than actually helping. Think sleeper nailed it. Though might want to get 30p also. Read and understand how to do a plug chop/read. Quote Link to comment Share on other sites More sharing options...
Ronaldkrause Posted February 17, 2016 Report Share Posted February 17, 2016 What the fuck... absolutely not.... I would call a site sponsor for INPUT well before paying someone to jet a bike... especially a unknown local shop.. end up with more bad then good. Sleeper nailed it and so did Larry.... the VF4 apparently like a larger pilot then the typical VF3's or equivalent.... I ment tell them and they can give you the proper jet size to do it your self Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 17, 2016 Report Share Posted February 17, 2016 I ment tell them and they can give you the proper jet size to do it your self Sent from my iPhone using Tapatalk Most place will look on the computer see oem sizes and just give you that. Anything other then what the computer says, your asking for trouble. Hopefully there's an older tech in the back that has a clue that can maybe help out. But it's usually some MMI bad ass fighting to change a tire. Quote Link to comment Share on other sites More sharing options...
Ronaldkrause Posted February 17, 2016 Report Share Posted February 17, 2016 Most place will look on the computer see oem sizes and just give you that. Anything other then what the computer says, your asking for trouble. Hopefully there's an older tech in the back that has a clue that can maybe help out. But it's usually some MMI bad ass fighting to change a tire.Lma im in utah and there are tons of shops that pretty much specialize in banshees Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ronaldkrause Posted February 17, 2016 Report Share Posted February 17, 2016 yea... ive heard of plenty shops that specialize in banshee's hack up some bikes pretty good too...Yeah that's probably true ive never let anyone work on my bike Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 18, 2016 Report Share Posted February 18, 2016 If i were you i would go into a shop that knows alot about banshees and tou. An tell them that all your mods are and they can gibe you a pretty accurate size Sent from my iPhone using Tapatalk There is a whole thread here that has several combos with jetting specs here. Quote Link to comment Share on other sites More sharing options...
Shee_fast Posted February 18, 2016 Report Share Posted February 18, 2016 Id start at 310 main 27.5 pilot plug chop...then adjust arrcordingly..also maybe run 40.1 that might help a little and won't hurt it running good oil like klotz Sent from my VS810PP using Tapatalk Quote Link to comment Share on other sites More sharing options...
