Ronaldkrause Posted February 16, 2016 Report Posted February 16, 2016 I just put cpi inframes on my banshee its all stock outher than k and n filters but there is no power in first and second gear all the outher gears have tons of power any suggestions Quote
trickedcarbine Posted February 16, 2016 Report Posted February 16, 2016 What jets? Where is the air screw set at? Quote
Ronaldkrause Posted February 16, 2016 Author Report Posted February 16, 2016 320 mains 30 pilots air screw is at 2.5 I believe Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted February 16, 2016 Report Posted February 16, 2016 Stock exhaust before the switch or something else aftermarket? And it ran good and clean? Try: Fresh plugs, check plug gap, check pick up gap, possibly back the pilot down to a 27.5 pilot. It should be close with a 30 in it though. Clean the carbs. Check that the pilot isn't all goobered up and plow out the ports with air and brake parts cleaner if you don't have a good parts washer. Quote
Ronaldkrause Posted February 16, 2016 Author Report Posted February 16, 2016 It was all stock then i did the pipes and filters. It ran great before the pipes. Pilot and main jet are new. Sent from my iPhone using Tapatalk Quote
Ronaldkrause Posted February 16, 2016 Author Report Posted February 16, 2016 What do you mean plow out the ports Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted February 16, 2016 Report Posted February 16, 2016 (edited) What do you mean plow out the ports Sent from my iPhone using Tapatalk Oh shoot, should of said BLOW* out the ports. Edited February 16, 2016 by trickedcarbine Quote
trickedcarbine Posted February 16, 2016 Report Posted February 16, 2016 (edited) Did you have both carb bowls off at the same time? If so they could of been switched. They are side specific. Slides are in the carbs with the cut away facing the back? Edited February 16, 2016 by trickedcarbine Quote
Ronaldkrause Posted February 16, 2016 Author Report Posted February 16, 2016 No i think i did them at the same time but ill check that. Sent from my iPhone using Tapatalk Quote
