Hey guys, im redoing my stock banshee and wanted some input on what size jets i should use. I have already ordered the vito's jet kit for upgraded exhaust and filter. Ok so right now it is stock with a K&n stock air box (has wholes drilled in top but a sticker covering the wholes, should i take off the sticker?) i believe all the jets r stock as well. If all i was doing was adding Pro circuit plat pipes and silencers which jets should i use?
Might be picking up a trinity cool head for $100 off craigs too, i know that would change my jetting. Any info on that? And if so recomendations on jet size for 21cc domes down to 19cc.
Also anyone recomend the Vito's +6hp or +8hp superstock kit off ebay for $180?
Wow that is alot guys. Thanks for your time and imput! Much appreciated.
First read up on how to do a plug chop. Same process to read plugs.
Just filter as you describe, one maybe two sizes larger than stock. Always start large and work down.
Notice kit says pipe AND filter, might not have small enough for just filter.
  • Like 1
  • 1 month later...
