mailman Posted January 31, 2016 Report Share Posted January 31, 2016 (edited) I wanted to take a little time and post a quick review on the new Driveline Cylinders. These are a great option when replacing your stock cylinders or just looking for more bolt on power. Lane was great to work with. He answers emails quickly and knows his product very well. I installed his cylinders on a stock stroke crank and used his 22 cc domes. This was NOT a "Shoot for the moon" build. It was very far from optimal due to a limited budget. Pipes could be better, carbs need to be bigger, compression and fuel could be better, filters could be better, timing could be advanced a little more, ports could be modded, etc. etc. This, to me, is an "Average Joe" bike/motor with a few mods to start with and a pump gas bolt on kit that just about anyone could do. Details: Bike already had T5 exhaust, Uni pod filters, stock carbs, Cool Head, and Vforce 3 reeds. I put on the Driveline cylinders and 22cc domes, adjustable timing plate at 4.5*, and taper bored stock carbs. Kicking compression was only 135 psi. This is a safe pump gas setup. I cleaned up the castings a little on the intake and exhaust. 350 mains, 27.5 pilots, stock needles middle clip, 1200 ft. Phoenix Here is the same setup with stock cylinders so you can see the before and after. Same graph but with TQ added. Edited January 31, 2016 by mailman 4 Quote Link to comment Share on other sites More sharing options...
mailman Posted January 31, 2016 Author Report Share Posted January 31, 2016 correct, stock unported engine with vforce reeds and T5 exhaust compared to a 68mm bore clean up Driveline cylinder. I thought for the money, it was a pretty darn good value with plenty of room for future mods as the budget allows. For the record; I don't know Lane personally. I just thought members would like an honest unbiased review of this product of his. 1 Quote Link to comment Share on other sites More sharing options...
gusto Posted January 31, 2016 Report Share Posted January 31, 2016 Mailman, thank you. I will be buying a set of these cylinders and have been waiting to see some graphs. That is great power curve! Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted January 31, 2016 Report Share Posted January 31, 2016 Stock jugs and carbs, non ported and T5 at 67hp? Did i miss something? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted January 31, 2016 Report Share Posted January 31, 2016 Stock jugs and carbs, non ported and T5 at 67hp? Did i miss something? no 47. I miss understood that too until I looked again. Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted January 31, 2016 Report Share Posted January 31, 2016 That's pretty good for the over all setup. I plan on doing a set of 392's for my stock stroke/ stock cylinder 55hp bike this spring. I was shooting for 70-75hp with stock carbs, vf3 reeds, shearer 2 into 1 pipe. Looks like its going to be pretty obtainable. 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 31, 2016 Report Share Posted January 31, 2016 Not shabby. Lots of potential there. The bonus is how linear the power is. 2 Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted January 31, 2016 Report Share Posted January 31, 2016 no 47. I miss understood that too until I looked again.Yup my bad ! Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted January 31, 2016 Report Share Posted January 31, 2016 Impressive, but I'm wondering what you experienced guys with built motors have to say. I'm not knocking these cyls by any stretch, but is this power curve comparable to other SS 392's? Don't get me wrong, that curve looks fun as hell to ride, especially since his stock motor is damn near identical to my stock motor and mods with the exception of his added compression. And what are your thoughts on how a set of PC's would do on this motor? Everyone says T5's are lazy and PC's rev harder up the face and rev the same or better than T5's. Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted January 31, 2016 Report Share Posted January 31, 2016 Impressive, but I'm wondering what you experienced guys with built motors have to say. I'm not knocking these cyls by any stretch, but is this power curve comparable to other SS 392's? Don't get me wrong, that curve looks fun as hell to ride, especially since his stock motor is damn near identical to my stock motor and mods with the exception of his added compression. And what are your thoughts on how a set of PC's would do on this motor? Everyone says T5's are lazy and PC's rev harder up the face and rev the same or better than T5's. As biased as my opinion may be, to be knocking on 70hp/40ftlbs with stock carbs, 135psi and t5s is pretty good. Upgrades to any of those 3 components will net a few hp at a time. Switch to 28-35mm carbs is going to be 3-5hp, 20psi more and still running premium pump gas is going to help and a pipe change could yield another 5-7hp depending on pipe. Looks like the toomeys are pulling rpm passed what I usually see, it may be the lower compression helping it pull long. A carb and dome swap, leave the t5's I bet its close to 75hp/40ftlbs. 2 Quote Link to comment Share on other sites More sharing options...
Craig B Posted January 31, 2016 Report Share Posted January 31, 2016 Nice review Mailman! Kind of gives me an idea where I was at with my Driveline cyl's, 35 pwk's and a 170 psi on race gas. I bet was close to 72 / 75 hp. Thanks for doing this. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 31, 2016 Report Share Posted January 31, 2016 Impressive, but I'm wondering what you experienced guys with built motors have to say. I'm not knocking these cyls by any stretch, but is this power curve comparable to other SS 392's? Don't get me wrong, that curve looks fun as hell to ride, especially since his stock motor is damn near identical to my stock motor and mods with the exception of his added compression. And what are your thoughts on how a set of PC's would do on this motor? Everyone says T5's are lazy and PC's rev harder up the face and rev the same or better than T5's. What added compression? Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted January 31, 2016 Report Share Posted January 31, 2016 What added compression? In his last paragraph he mentioned he had a cool head. Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted January 31, 2016 Report Share Posted January 31, 2016 OK, you guys could be right, but why would anyone put a cool head on and not bump up compression? My motor is old and tired kickin 120psi cold. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 31, 2016 Report Share Posted January 31, 2016 OK, you guys could be right, but why would anyone put a cool head on and not bump up compression? My motor is old and tired kickin 120psi cold. Because certain dome shapes/profiles can perform better then others. Plus the Cool Head allows you to switch domes pretty easily, versus having a new head cut each time you wanna change it. Quote Link to comment Share on other sites More sharing options...
