Texan99 Posted January 30, 2016 Report Posted January 30, 2016 Anyone have the issue of pt mids hitting the stock petcock? Or have more clearance with a dual pingel? Sent from my iPhone using Tapatalk Quote
sheerider11 Posted January 31, 2016 Report Posted January 31, 2016 Woah. They shouldn't be that high at all 1 Quote
hoppedupandcutdown Posted January 31, 2016 Report Posted January 31, 2016 Spurdy's son had the same problem, but mine didn't hit. Quote
rjdgriff Posted January 31, 2016 Report Posted January 31, 2016 I had a set of pt mids and they hit like a bitch Trail bikes, FTW Quote
Big Mike NY Posted January 31, 2016 Report Posted January 31, 2016 Shit how the fuck do you correct that?? Quote
Texan99 Posted January 31, 2016 Author Report Posted January 31, 2016 Ima try a dual pingel out before I start bending shit. Seems to have better clearance when I compare it to my buddies Banshee who's pipes seem to run higher than others I've seen. Here's a comparison. Sent from my iPhone using Tapatalk Quote
bluebanshee98 Posted January 31, 2016 Report Posted January 31, 2016 You could prob put some half inch spacers on the rear side of the tank. That may help 1 Quote
Texan99 Posted January 31, 2016 Author Report Posted January 31, 2016 I noticed my pipe hangers were ripping apart making it bend closer. Ordered some new ones so in a couple days I'll see if that makes a difference as well. Sent from my iPhone using Tapatalk Quote
rjdgriff Posted January 31, 2016 Report Posted January 31, 2016 I just bought new pipes lol Trail bikes, FTW Quote
Texan99 Posted January 31, 2016 Author Report Posted January 31, 2016 These pipes damn near look new, I haven't seen in person this nice of used PTs before. Ima try what bluebanshee98 said with the spacers on the rear side of the tank. Sent from my iPhone using Tapatalk Quote
LaegerEliminator Posted January 31, 2016 Report Posted January 31, 2016 You might try a washer or two between your pipe hanger and the frame to lean the pipe away from the petcock. Also you might be able to trim a small amount of aluminum off of your forward most silencer mount to further move things away. Just enough to keep the silencer from touching your frame if there is any excess currently. Quote
