trickedcarbine Posted February 2, 2016 Report Share Posted February 2, 2016 Sorry, I gave the wrong info. It was in an Ice Racing thread. Here is how to ditch the plate. I'd Imagine you could clean it up even more by grinding that section with the bungs off and mount it straight to the engine cradle tube. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted February 2, 2016 Author Report Share Posted February 2, 2016 I definitely want more cut off than that. A1 is for fags. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 2, 2016 Report Share Posted February 2, 2016 Seamed or seamless tube? Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted February 2, 2016 Author Report Share Posted February 2, 2016 Seamless 4130. A1 is for fags. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 2, 2016 Report Share Posted February 2, 2016 So Dom Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 2, 2016 Report Share Posted February 2, 2016 Your not building a drag bike, if you do what's pictured there it will snap and you will get hurt. Your jumping rite 1 Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted February 2, 2016 Author Report Share Posted February 2, 2016 Yes, it'll need to be more durable for sure, but I don't want that cluster. I've been thinking about it and I think that the 6" x 15/16 OD insert tubing would do well inside of some 15/16 ID (probably 1.5" long) that will also act as a stop for the nerfs. I could gusset the outer piece. A1 is for fags. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 2, 2016 Report Share Posted February 2, 2016 I definitely want more cut off than that. A1 is for fags. That's what I meant by grind the outer gusset and bungs off so you can mount it directly to the frame tube. Might need to put some sort of collar on the tube though, so that the nerfs sit out where they should. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted February 2, 2016 Report Share Posted February 2, 2016 What cluster are you talking about? I dont know that id feel comfertable running a peg like that on an mx or even a trail bike. To each their own... Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted February 3, 2016 Author Report Share Posted February 3, 2016 This is what I was thinking. Open to suggesions. Green arrow references the rear of the frame. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 3, 2016 Report Share Posted February 3, 2016 Seems completely unnecessary to me. DDQ is out there doing some pretty big jumps with what I assume are stock type pegs or nerfs that bolt to OEM mounts. Why do you think you need this? Are you a pro MX rider or are we missing something? Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted February 3, 2016 Author Report Share Posted February 3, 2016 I just want to shave weight. I can't just run off the end of the lowest tube because I'd have to either hack the nerfs or start hacking on the frame even more to make it fit. If I was to weld on an insert, it would have to have additional support. It's just the insert and one bracing tube. That's as simple and effective as I could figure. I think I could net 3lbs from doing this. If it won't work, I'll scrap the idea but I want to find a solution if it's possible to make it work safely and effectively. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted February 3, 2016 Report Share Posted February 3, 2016 3 pounds? Fuck this idea. You're way over complicating it. 1 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 3, 2016 Report Share Posted February 3, 2016 3 pounds? Fuck this idea. You're way over complicating it. I agree. No offense, but if you have to ask how to do it you probably shouldn't be attempting it yourself. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 3, 2016 Report Share Posted February 3, 2016 (edited) There is 4 square nuts inside there, and two gussets. You are replacing it with a foot and a half of chromoly tube in that drawing. There is no way you are getting rid of 3 lbs. of chassis weight. But I do dig the way that looks. Edited February 3, 2016 by trickedcarbine Quote Link to comment Share on other sites More sharing options...
