Deezy804 Posted January 26, 2016 Report Share Posted January 26, 2016 I rode my banshee and the next day I go to ride the left cylinder is dead I know it's gettin fuel cause my headers fill up with gas that isn't burning and when I empty the header of the extra gas it fires case it's pushing the rest of the gas out but it's very weak. and it is getting fire so what y'all thinks the problem Quote Link to comment Share on other sites More sharing options...
Phelps Posted January 26, 2016 Report Share Posted January 26, 2016 you need fuel, compression and spark. you have already ruled out fuel. Quote Link to comment Share on other sites More sharing options...
Deezy804 Posted January 26, 2016 Author Report Share Posted January 26, 2016 Compression and spark good .. 60 over brand new wiseco pro lite... When I start it the header fills up with gas but when I dump it it fires really weak and fills up again Quote Link to comment Share on other sites More sharing options...
Phelps Posted January 26, 2016 Report Share Posted January 26, 2016 check the float needle. compression is good because it's a new topend? you know how many 5 minute old topends i have seen with a broken ring because the ports were not chamfered? Quote Link to comment Share on other sites More sharing options...
Deezy804 Posted January 26, 2016 Author Report Share Posted January 26, 2016 Yea I think it's the dam float to man I don't even have 5hrs on the fresh top end, also hear it could possibly be bad reeds but I kinda doubt that but def considered it Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted January 26, 2016 Report Share Posted January 26, 2016 It takes 2 minutes to do a comp test. Also rule out another possible issue. Like stated, just because it's new that doesn't mean it's okay. I'd do that before I start taking shit apart also. Do all the simple test. Then you can visually check if you have spark too. Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted January 26, 2016 Report Share Posted January 26, 2016 Bad spark plug boot, check pick-up gap on the flywheel, besides the other stuff that has been mentioned. Quote Link to comment Share on other sites More sharing options...
Deezy804 Posted January 26, 2016 Author Report Share Posted January 26, 2016 I was just riding the bike a day before and this happend all of a sudden but I'm taking the carb off tomorrow and check the float and I'll keep you guys posted and thanks Quote Link to comment Share on other sites More sharing options...
Phelps Posted January 27, 2016 Report Share Posted January 27, 2016 while the carb is off do the best you can with a light to inspect the reeds. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted January 27, 2016 Report Share Posted January 27, 2016 Take carb completely apart and clean it, set float s Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted January 27, 2016 Report Share Posted January 27, 2016 Reeds Quote Link to comment Share on other sites More sharing options...
Deezy804 Posted January 31, 2016 Author Report Share Posted January 31, 2016 Thanks fellas come to find out it was the piece that works the slide from the throttle , the screws came out and the slide was never moving n the carb Quote Link to comment Share on other sites More sharing options...
