chase@miamiatv.com Posted January 25, 2016 Report Share Posted January 25, 2016 Everythings been great for 20 hours on the banshee , First time clutch lever went completely out on a pass .... i opend it up and found the adjustment screw like this ... ....... Found a washer and another nut in the clutch cover crannies ....... I put the washer on , adjusted it normally , put the outer nut on ... tightend it , closed motor ......... Everything worked better then before , 4 passes later ..... back to same problem....... going to get the pancake bearing now , but is there anything else i should look for causing this ? do i need to locktight the outer nut from coming out of adjustment ? welded ball ? Do the pancake bearings require the ball ? Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted January 25, 2016 Author Report Share Posted January 25, 2016 This is not the same quad as last months clutch issue . Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted January 25, 2016 Report Share Posted January 25, 2016 Make sure your ball/rod isn't welded. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted January 25, 2016 Report Share Posted January 25, 2016 I locktight all of them , clean threads with brake clean or ascetone , locktite then tighten 1 Quote Link to comment Share on other sites More sharing options...
Phelps Posted January 25, 2016 Report Share Posted January 25, 2016 id suspect the ball has welded to the rod as mentioned. Quote Link to comment Share on other sites More sharing options...
