Thanks for that... I was thinking to maybe play around with the kx,yz and rm JD jetting kit... Maybe one of the needles would come out on top... I did ask JD and said they have never tested anything like that before... Would be awesome if they could do some tests on 2:1 setups with 35mm and 38mm....
I know nothing about that dirt bike needle. IMO get it running with the known good eek then you can experiment. There's 100s of people running the eek with great results , I don't see any reason to reinvent the wheel. The fact of the matter is extensive testing has been done to these set ups if there was some majic
Steer clear of the dirt bike kit. They are for a single cylinder motor 100cc's smaller and a different carb then you were wanting to run all together.
